  • 1994 - 1995 Specific Tech
Tweecer
  • Thread starter Thread starter 94indy
  • Start date Start date Jun 18, 2005
94indy
33
hattiesburg
Jun 18, 2005
  • Jun 18, 2005
I couple of days a ago I bought a S-trim, since I am still running my stock computer no chip I decided to by the Tweecer also, which I should get mondady. Just wondering how hard is it to program the stock 94 computer with it and what the learning curve is. I ve already found some info on the net about the changing of the spark advanced on the 94-95 computer since it retards the timing between shifts.
Zero Signal
2,633
Tucson, AZ
Jun 18, 2005
  • Jun 18, 2005
It's called tip-in-retard. I'll say the tweecer probably takes alot more to learn to use effectively than most systems. One thing is that you can easily screw things up by using it. You will have direct control over the computer so you just have to be carefull and know what you are tinkering with. 90% of what you can change with the thing is undocumented so you really have to do some research.
But with that said, I love that about the tweecer, I never regret having bought it. It will do everything you want it to do.
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Jun 18, 2005
  • Jun 18, 2005
IM surprised you bought it before asking these questions. Go to the TwEECer boards to get your initial tune...then make adjustments as needed from there. You would start with the fan settings, EGR/Smog Pump delete, and idle....Save those settings on position one, then do small adjustments from there.
RC
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 18, 2005
  • Jun 18, 2005
Considering your combo is forced induction, a wide band to go along with the Tweecer will be a must have item or you will be totally dependent on a dyno session to get your wot fuel ratio where you want it, and in your case, where you need it.
You can get help here as others have said
http://eectuning.org/forums/
be sure to check out the faqs section
Later
Grady
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
