Twin Turbo Help...
  • Thread starter Thread starter MikeH686
  • Start date Start date Jan 23, 2015
First Prev 2 of 2
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Jan 26, 2015
#21
  • Jan 26, 2015
  • #21
My 363 took 11 psi to clear 600 rwhp.
What is the rest of the car? rear end, brakes, cooling, suspension, trans, fuel and most importantly block?
Making 600 rwhp is not all that hard, doing so reliably and repeatably takes a good bit of cash.
my 363 with an old school Precision 76GTS with all the supporting parts made over 950 rwhp (26psi) and through a 3" down pipe. I hope you have equal amount of time, patience and money for your build
Reactions: A5literMan
MikeH686
Mine is only two inches though.
2,843
1,753
184
Waldorf, MD
Jan 26, 2015
#22
  • Jan 26, 2015
  • #22
Block is stock I know shocker it won't hold the 600 but I'm gonna try its got scat crank eagle h beam rods Ross Pistons. Edelbrock 185cc with valve job. Systemax intake 30 lb injectors stock fuel lines and rails (will be swapped when installing turbo). Upr suspension coilovers up front and out back with double adjustable uppers and single adjustable lowers. 275/40/17 nitto nt05r tires. The car is built to have a power adder with an 8.5:1 compression ratio. Cooling is stock with a 180* thermostat and a fluidyne 3 row radiator.
MikeH686
2,843
1,753
184
Waldorf, MD
Jan 26, 2015
#23
  • Jan 26, 2015
  • #23
Oh and a trick flow stage one can which will be swapped out and getting a custom cam when I do the build no sense in having it in now when there isn't a power adder
Boosted92LX
5,721
4,244
224
Jan 26, 2015
#24
  • Jan 26, 2015
  • #24
MikeH686 said:
Oh I forgot I am a 347 not a 302 @Boosted92LX
The pt 7175 was exactly what I was going to use, but the bb version was just too pricey for me. I think the .96 would be just right for a 347 from all the reading I've done.. but again. . Check the turbo forums and verify the combination over there. Guaranteed someone over there is using it and they are happy to chime in with advice. The place is priceless.
MikeH686
2,843
1,753
184
Waldorf, MD
Jan 26, 2015
#25
  • Jan 26, 2015
  • #25
Yeah ball bearing pt7175 was over 2300 bucks haha yeah I need to get apart of a turbo forum and snoop around there
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Jan 26, 2015
#26
  • Jan 26, 2015
  • #26
The rest of you combo is not going to support 600 rwhp.
not enough fuel system
no mention of trans, assume stock t5
rear end gears/axles?
stock brakes?
what about ECU I guess a custom chip also just because its low compression that does not make it "built for boost" my motor is 9.3:1 which is higher than stock and it was indeed built for boost. Often times low compression motors are lazy and somewhat dogish down low. Also not a fan of putting higher end parts into a stock block, remember the block is the weak point and can and often will destroy all those nice internals when it lets go.
As mentioned you need to get to the turboforums and read,
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Jan 26, 2015
#27
  • Jan 26, 2015
  • #27
The block will stay together....for awhile. How long? @600rwhp not very long. Are you sure your compression is that low? Might want to spend the "turbo" money on a good block/fuel system first.
MikeH686
2,843
1,753
184
Waldorf, MD
Jan 26, 2015
#28
  • Jan 26, 2015
  • #28
Forgot moser 31 spline axles 03-04 cobra front brAkes upgraded discs in the rear 11.5". Transmission is a c4 manual valve body with a brake rated at 675 ft. Lb. of torque and @GroverDill I mentioned that I knew the fuel system was not enough and that I was going to be upgrading to support the added air. This is also not 600 to the wheels either this is 650 to the crank so roughly 570 to the wheels or possibly less. Also stock rails can support 42 lb injectors will will support in the 650 bhp range.
MikeH686
2,843
1,753
184
Waldorf, MD
Jan 26, 2015
#29
  • Jan 26, 2015
  • #29
Yes @A5literMan im positive the compression is that low because that's how I had it built.
A5literMan
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Jan 26, 2015
#30
  • Jan 26, 2015
  • #30
Any possibility of milling the heads to bump it? Not a huge problem(8.5cr) but like Grover stated low cr motors tend to be a little lazier. Again this would be less of a problem if it were a race motor and you could stage with the turbo already spooling a little. even @ your proposed power level the block is going to be a concern. Id probably sell/trade/swap into a block upgrade first. But again I just spent a bunch of cash on my stock block/build. Lol
Reactions: MikeH686
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
Jan 26, 2015
#31
  • Jan 26, 2015
  • #31
my buddy runs a 70 on a 357w with Vic jr car is 9.08 knocking on 8.99 just saying
FoxMustangLvr
I love my Pimp
SN Certified Technician
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Jan 26, 2015
#32
  • Jan 26, 2015
  • #32
Reading this thread reminded me of a thread that once was a sticky.............
http://www.stangnet.com/mustang-forums/threads/500-rwhp-stock-b-this.867481/
Reactions: MikeH686
MikeH686
2,843
1,753
184
Waldorf, MD
Jan 26, 2015
#33
  • Jan 26, 2015
  • #33
@FoxMustangLvr i hope it lasts six years I'm not gonna daily this thing hall I'll probably only five it about 500 miles in a year. That's how much I drove it last year.
Reactions: A5literMan and TOOLOW91
A5literMan
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Jan 26, 2015
#34
  • Jan 26, 2015
  • #34
I only drove mine about 100 miles this year. But I plan on driving the crap out of it this summer. Your block will probably be ok for awhile if you stay in the moderate boost range and keep the rpms under 6k.
MikeH686
2,843
1,753
184
Waldorf, MD
Jan 26, 2015
#35
  • Jan 26, 2015
  • #35
Yeah I plan on keeping it around 4500-5000 I speced everything to 6000 though. I was supposed to get a R block from @84Ttop but well we will just leave it at that
A5literMan
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Jan 26, 2015
#36
  • Jan 26, 2015
  • #36
If you keep an eye out on the corral they become available at a good price. You could order a new block and swap everything over.?
MikeH686
2,843
1,753
184
Waldorf, MD
Jan 26, 2015
#37
  • Jan 26, 2015
  • #37
That's the plan hopefully sell the heads and get a set of 205
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Jan 27, 2015
#38
  • Jan 27, 2015
  • #38
I don't even want to talk about this....... It was a sad sad sad sad day. Thanks for reminding me
hoopty5.0
mechanicus terribilis
7,850
6,992
214
SW Houston
Jan 27, 2015
#39
  • Jan 27, 2015
  • #39
They make new blocks every day too.
Reactions: A5literMan, TOOLOW91 and Boosted92LX
MikeH686
2,843
1,753
184
Waldorf, MD
Jan 27, 2015
#40
  • Jan 27, 2015
  • #40
Yup that they do
First Prev 2 of 2
V
pushrod 5.0 (MILD/ Torque) turbo build for an old scout II help
  • vz58
  • Apr 21, 2024
  • Other Auto Tech
2K
Other Auto Tech Jan 21, 2026
Flyboy60
F
For Sale SW MI: A tale of Two 20G Turbos
  • JmP6889928
  • Mar 21, 2022
  • Other Classifieds
Other Classifieds Mar 21, 2022
JmP6889928
Help me identify this turbo
  • Hoytster
  • Oct 16, 2018
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 16, 2018
Hoytster
Progress Thread Dirty Water Racing 89 Notch Project
  • ShedBuiltMS
  • Sep 29, 2020
  • 2 3 4
14K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2021
Flyboy60
F
For Sale 2013 Hellion Twin turbo Mustang GT
  • Hellion2013
  • Aug 28, 2018
  • S197 Mustangs For Sale (2005-14)
4K
S197 Mustangs For Sale (2005-14) Aug 28, 2018
Hellion2013
