- Sep 26, 2004
- 184
- 0
- 0
Well guys after a year in Iraq, Ive got one bad Saleen now. Mod list follows:
.20 VT Shortblock, w/ Cobra Crank, Billet Oil Pump Gears, Stock Heads and Cams, Canton Oil Pan
HP Twin 57mm Turbos
QA-1 Tubular K Member w/ Coil Overs
42lb Injectors
Kenne Bell BAP
Cobra Tank and Pumps
Electronic Boost Controller
Accufab Plenum w/ 75mm Throttle body
MM Caster Camber Plates
MM Full Length Subframes
MM Strut Tower Brace
SPEC III Clutch and Steel Flywheel
31 Spline Axles, w/ Eaton Posi, 3:73 FRPP Gears, and Saleen Dif Cover
FRPP Aluminum Driveshaft
MM Upper and Lower Control Arms
90mm LMAF w/ SCT MAF Extender
Steeda Tri Ax Short Throw Shifter
Autometer Luner, Boost, Fuel Pressure, Oil Pressure, A/F, and Water Temp Guages
SCT Chip
All work was done by Modular Powerhouse, and tuned by Tim Barth!!!
Rhonda called me this morning with the numbers,
508RWHP and 591 torque!!!!!
Very nice numbers, awesome job done by the crew at MPH, they are the BEST!!!
HP Twin 57mm Turbos
42lb Injectors
Kenne Bell BAP
SCT Chip
