Twisted Wedge Heads
  • Thread starter Thread starter ga94gt
  • Start date Start date Sep 5, 2007
G
ga94gt
138
Ringgold GA
Sep 5, 2007
  • Sep 5, 2007
I am looking into a Twisted Wedge top end kit and it comes with the non-oringed heads. Is there going to be a difference between the non-oringed and the oringed heads. Would the oringed heads be better?
Any info would be great.
Thanks Garrett
91 HATCH
Banned
May 17, 2007
262
illinois
Sep 5, 2007
  • Sep 5, 2007
if you plan on boost i would get the o ringed heads
D
Daggar
3,902
  • Sep 5, 2007
Personally, I do not see the need for O-ringed gaskets anymore. If the tune is going to be good and you KNOW it's going to be good then run regular head surfaces and a set of cometic gaskets.
Your internal parts will give before the cometics do. They also require a little more prep of the mating surfaces than regular head gaskets.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 5, 2007
  • Sep 5, 2007
O-ringed heads have a groove that is cut around each chamber in the surface of the head that meets the block. Then special o-ringed head gaskets are used to fit into the groove, that when bolted down, create a seal around each cylinder to allow for more cylinder pressure. Be sure to use a set of quality gaskets, for they are vital in creating a strong seal between the heads and the block.
As alluded too, unless you are looking to make big power or lots of boost, a regular design cosmetic headgasket will work fine. Use ARP head studs.
Here are the headgaskets recommended by Trickflow:
Fel-Pro 8548PT-2 for mild engines with non O-ringed heads.
Fel-Pro 1011-2 for higher performance engines with non O-ringed heads.
Fel-Pro 1022 and 1023 for non O-ringed heads with wider combustion chambers due to porting (1022 is for the left bank, 1023 is for the right bank).
Fel-Pro 1006 or TFS-51400901 for all engines with O-ringed heads.
Street Heat/Twisted Wedge Heads:
TFS-51400003 – TW/Street, 170cc Head, 61cc, 1.470" Single Valve Spring (.540”), 7* locks, 3/8” rocker studs, smog provisions and machined for o-rings. $1,310.
TFS-51400005 – TW/Street, 170cc Head, 61cc, 1.460" Dual Valve Spring (.600”), 7* locks, 3/8” rocker studs, smog provisions, and machined for o-rings. $1,340.
Track Heat Heads:
TFS-51400011 – Track Heat, 170cc Head, 61cc, 1.460" Dual Valve Springs (.600”), 10* locks, 7/16” rocker studs, no smog provisions, and machined for o-rings. $1,380.
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Engine Head gasket port matching plus head/intake port alignment
  • PonyGTrider
  • Dec 10, 2024
Fox 5.0 Mustang Tech Dec 12, 2024
PonyGTrider
