  • SN95 V6 Mustang Tech
Two problems!
  • Thread starter Thread starter Fstang1998
  • Start date Start date Feb 3, 2009
Fstang1998
  • Feb 3, 2009
I drive a 98, automatic transmission, no mods.
Sometimes when I turn off my car, it will make a very strange squeak from the engine bay, it sounds like the beginnings of a police siren, will last anywhere from less then 1 to 5 seconds. After the first squeak goes away, occasionally there will be a second squeak, again, lasting anywhere from less then 1 to 5 seconds. I honestly have no idea what this sound is. It seems to happen more often when it is warm (50 degrees or more) and the car is up to temperature. My check engine light is on, but it's because of a bad O2 sensor. Has anybody ever encountered this problem before? I don't really know how else to describe it.
The second problem is that sometimes when I am driving less than 25 mph, and my foot is not on the break, I will get a moaning sound from the back of the car, it seems to be worse when it is below freezing outside and it goes in time with the wheel rotation, which leads me to believe that it is a rubbing brake pad, but I wanted to get a second opinion before I replace my brakes.
Thank you for any help you can provide me with!
MustangLX-5.0
856
Lehigh Acres Fla.
Feb 3, 2009
  • Feb 3, 2009
First problem sounds like you have a vacuum leak possibly at the brake booster.It retains vacuum after the car has shut off so it could be leaking through a rubber seal.Or this could be a fuel line leak even.Do you ever smell gas or hear any hissing noises? I can't think of what else it could be.Sounds like something pressurized leaking against a rubber seal?? Is it loud? Very high pitched?
Second problem sounds like pads.Is it a slight humming sound mixed with a a slight scraping noise? Check your pads and rotors on the back.Make sure you have some usable pad left,and not rubbing metal to metal.I might also add that it is normal for a 'little' bit of humm or rubbing noise to be heard,scuffing especially if the rotors sat for a couple days and got wet.It's the rust of rotor surface oxidation that built up and is causing scuffing noises to be heard at low speeds.
Fstang1998
  • Feb 3, 2009
For the first problem, I never smell gas or hear a hissing, but yes, the noise is very loud and very high pitched. It does sound like something pressurized leaking against a seal. Is the brake booster hard to get to? Wouldn't it being a vacuum leak make it happen every time however, because it happens randomly.
For the second problem, I'll check my brakes after work tomorrow if I have time, if not, this weekend. It's more then a little sound being heard, it is quite loud and predominant.
Fstang1998
  • Feb 4, 2009
Replaced my rear brake pads today, it was a nightmare. Both of the caliper pistons wouldn't tighten unless I used a C-clamp to apply pressure while I used vice grips to twist them inward to engage the threads. On my passenger side, neither of the caliper pins had and grease on them from the previous owner, so one of them was pretty much rusted in place, had to use vice grips, a hammer, and a screwdriver. But I got the pads changed eventually (after 5.5 hours!). It remains to be seen if the sound goes away.
MustangLX-5.0
856
Lehigh Acres Fla.
Feb 5, 2009
  • Feb 5, 2009
Make sure you clean off that rust and added a generous ammount of caliper grease to those pins.Those are what allow the caliper to move freely,mainly for the outside pad.But if one cant move too well,it stops up the caliper.
Do you live in the north? Perhaps that would explain the rust.Either that or the brakes were riding the rotors and baking the metal.Both will cause nasty corrosion.
About the squealing noise your hearing.The booster was more of a suggestion.Something to check on.No its not hard to get to.You know where you add your brake fluid at (master cylinder) , The booster is the big black round thing underneath that.The sound 'could' be coming from the hose that connects on to it.The booster is constantly under a vacuum from the engine running.The booster stores a small amount of vacuum.When you shut the car off,the engine stops sucking (no pun intended) and any leak that is present will start equalizing the pressure from air being able to enter.Just a thought.Since it is random,a hose or something moves or vibrates from the previous time you started/drove your car.temperature causes things to expand & contract.Again,do you live in a very cold area?Since you aren't smelling fuel,I would doubt it is a fuel leak.Since it only happens briefly and is intermittent,it could be something that is only under temporary pressure (ends when you turn off engine) and unlike a radiator hose which would still retain lots of built up pressure for at least a half hour afterwards.
I can only guess right now.I cant tell you what is causing the noise.Do you have antilock brakes? How many miles are on it? Try this,open your hood and start the car.Let it run for about 15 minutes.Then,with your drivers window down,reach in and shut the car off and very quickly walk around to the engine area and see if you can tell where the noise is coming from.You may have to restart the engine and and then shut it back down after 10 seconds.Thats how I locate intermittent noises like that.
Fstang1998
  • Feb 5, 2009
I've also had the suggestion that it could be the fan belt. But yes, I live in colorado, so it is very cold quite often. I have antilock brakes, the car has 140k miles. I have tried to listen to the noise multiple times, but I have never been able to pinpoint it because it could be bouncing off all the metal and coming from anywhere.
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
1998 Mustang Gt Rattling sound, cannot locate. Video included
  • studerman1
  • Mar 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 1, 2026
studerman1
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
M
  • Mindseye007
  • Aug 16, 2026
Mindseye007
M
