SQUEEZE&STROKE said:I Think That Intake Is Based Off Of The Edelbrock Performer/performer Rpm. When I Say Based I Am Pretty Sure It Is Almost Identical, Sounds Like A Deal To Me...the Eddy Rpm Is Almost 500 By Itself
Synned said:Dude, you have a caps lock and a shift button for a reason.
And Its Not To Talk Like This Okay OR LIKE THIS.
It is based off the RPM...donnie84 said:yea i didnt know if it was the performer rpm or the performer. i would go with the eddy or cobra... but i cant use a 93 cobra intake with an elbow on my sn95 can i? i need to find a 94/95 cobra intake right?
SQUEEZE&STROKE said:WOW LOOKS LIKE I PUSHED SOMEBODY'S BUTTONS! MAYBE I WANT TO POST LIKE THIS...WHATS IT TO YOU ARE YOU GONNA HARP ON THE ABOVE POST FOR NOT USING THE SHIFT KEY?
The NJ Exile said:You will lose quite a bit of TQ down low.. I WOULD NOT use this manifold unless you have somethign else done other then simple bolt ons/
final5-0 said:I use one![]()
Take a look and tell me what you think![]()
Later
Grady
I wounls not use it with out heads and cam...On a stock long block you would be pissin' in the wind.
The NJ Exile said:You alittle got quite a bit more then simple bolton's...I wounls not use it with out heads and cam...On a stock long block you would be pissin' in the wind.
