Typhoon vacuum lines
  • Thread starter Thread starter Curse
  • Start date Start date Dec 3, 2004
Curse
791
El Paso, TX
Dec 3, 2004
  • Dec 3, 2004
Anyone have an extreme close up of the way you route the vacuums when installing a Typhoon intake in a fox body? I will be installing the Typhoon in a few days and want everything to go smoothly. Pretty much have everything figured out except the vacuum lines. I don’t understand the directions; this is my first intake swap, so still learning. If you need any more info just ask. Thanks
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Dec 3, 2004
  • Dec 3, 2004
easy stuff..from tb follow towards driver side...try to follow along. first after TB you have two vac ports...one facing front of car is to lead to charcoal canister, one facing back of car goes to fuel pressure regualtor. Move towards driver side of car on intake, facing back of car is multiple ports, which you need one to go to vac tree on firewall, and either block off other holes or if speed density connect one line to MAP on fire wall (BUT ONLY IF YOU ARE SPEED DENSITY 87-88 NON CALIFORNIA CAR). Last line comes from under intake, it is to be a 90* elbow that will connect to the PCV valve...that's it. One to fuel pressure reg, one to charcoal canister, one to vac tree on fire wall, one to pcv off bottom of intake. All other holes must be blocked off.
Curse
791
El Paso, TX
Dec 4, 2004
  • Dec 4, 2004
Thanks, sounds simple enough. Did you have a problem with fitting the PCV stuff in the Typhoon?
Curse
791
El Paso, TX
Dec 4, 2004
  • Dec 4, 2004
Does anyone see a problem with getting the vacuum for the FPR from the multiple ports on the driver side of the intake, instead of the port right behind the TB? All all my vacuums minus the charcoal canister and PCV, will be coming from the same multi-port thing on the back of the inatke on the drivers side. I just think it looks cleaner that way.
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Tuesday at 2:05 PM
Kleinjj27
K
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
Vacuum line question?
  • Mustang Momma
  • Feb 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 3, 2026
D
Brakes 88 LX 5.0 - help! no brakes
  • DRGunn427
  • Feb 26, 2025
Fox 5.0 Mustang Tech Feb 27, 2025
nickyb
