I've ordered a Spec Stage 2 clutch kit and billet steel flywheel for my Mach 1. Can anybody give me a ballpark figure of what it will cost to have the parts installed by an independent shop, not the Ford monkeys!
Thanks for the info. I'm hoping to keep it under $300. The design of the TR3650 with the integrated bellhousing sucks! To have to drop the tranny and driveshaft just to do a clutch install is ridiculous!BCB00GT said:I looked into the cost of a clutch install on my 00GT (T-45) and got three prices averaging $280 ($260-$300) using a new flywheel. I think the labor is about a 4 hour charge.
I am doing it myself next Friday with the help of a friend.
TR03Mach1 said:Thanks for the info. I'm hoping to keep it under $300. The design of the TR3650 with the integrated bellhousing sucks! To have to drop the tranny and driveshaft just to do a clutch install is ridiculous!
Thought maybe it was, but I wasn't real sure. If I could get it done for $250 in half a day, I'd be doing the Snoopy dance!V_Eight said:T45 is like that too.![]()
stangtrooper97 said:Jim, if you find a place let me know. My throw-out bearing is making alot of noise and I figured I should change the clutch while I'm in there. They are going to drop the tranny anyway.
Will do Pete! Hope to get it in sometime during the 4th of July week. While I appreciate the do-it-yourself responses, ain't gonna happen. I lack the necessary tool inventory and the inclination to drop the transmission (how can anybody say that's not a major undertaking?) of my daily driver onto the floor of my garage! I'm just trying to get a rough idea of what it costs to have an independent shop install the clutch. To the guy who got Ford to do it for $150, you're my hero! I'd love to know how you got them to do it for that price!stangtrooper97 said:Jim, if you find a place let me know. My throw-out bearing is making alot of noise and I figured I should change the clutch while I'm in there. They are going to drop the tranny anyway.
TR03Mach1 said:The design of the TR3650 with the integrated bellhousing sucks! To have to drop the tranny and driveshaft just to do a clutch install is ridiculous!![]()
AdRock said:That's an odd post.
On every car I've ever worked on you have to unhook the DS and pull the tranny to do the clutch. You can pull the tranny back with the DS still attached and you can't get to the clutch without pulling the tranny back.
Could be that's because the last clutch I installed was in a 1973 Plymouth 340 Duster, and all I had to do was get the car on a lift, unbolt the bottom half of the bellhousing, and remove the clutch fork, pressure plate, and clutch disc off the input shaft without ever touching a bolt on the transmission! Took 3 people with hand tools about an hour start to finish.AdRock said:That's an odd post.
On every car I've ever worked on you have to unhook the DS and pull the tranny to do the clutch. You can't pull the tranny back with the DS still attached and you can't get to the clutch without pulling the tranny back.
TR03Mach1 said:Could be that's because the last clutch I installed was in a 1973 Plymouth 340 Duster, and all I had to do was get the car on a lift, unbolt the bottom half of the bellhousing, and remove the clutch fork, pressure plate, and clutch disc off the input shaft without ever touching a bolt on the transmission! Took 3 people with hand tools about an hour start to finish.
