U/D pulleys and T/A question
5spdBlack
44
NJ
Hey guys I tried a search but didn't find the exact answer I was looking for.
I'm thinking about getting some Steeda U/D pulleys and a Steeda T/A becuase I hear its a good idea to get both at once. However, I have a few questions.
1) what does the timing adjuster actually do?
2) I plan on getting the Diablosport Predator eventually, can't that essentially do the same thing as the T/A?
Thanks a lot guys
Timing adjusters are an ill-advised mod on engines that electronically control their own timing advance :notnice:
If you use a handheld engine programmer such as an SCT XCal2 you can adjust timing much more effectively.
Pullies suck also :notnice:
yeah i dont like the T/A either the tuner is overall a better investment cause you can adjust the A/F ratio and do other things for one, with it being just one purchase :nice:
i went with both and regret it because i got supercharged a few months after
the pulleys didnt really do much, but the t/a was a waste totally.. a chip/tune will do the same and save you labor charges
You should save your funds and get a SCT Xcal2 it's we'll worth it.
Also the only underdrive pulleys I would consider for are cars would
be the Steeda underdrive pulleys because they are non-piggyback
pulleys.I have been useing the Steeda underdrive pulleys on my car
for three years now with no issues at all.
Steeda pullies if you go with pullies. Tuner is a good investment if you're going to change you're axle ratio later. See my sig, for my results as I've been making changes. The biggest power gain from one bolt-on was the off road x-pipe. BBK x-pipes don't sound the greatest, but the power gain, I found impressive.
+1
2 yrs here with Steeda Pulleys with No issues
awesome thanks guys! I was planning on going with the Steeda pullies as I hear they are the best, and I don't think i'll be getting the T/A. I plan on getting 4.10's eventually so i'll just get a handheld engine programmer with those. Thanks again :nice:
Agreed, good plan. I think most issues with pullies are due to improper installation, so do them right. Yeah, skip the TA (old school) and get an SCT Xcal2.
Steeda's are not the only non-piggyback pullies out there. Motoblue's are also I believe the ASAP's are too.
UD's - Pro's frees up a few ponies, engine rev's a little more freely. CONS - Ac don't work as well, and did I mention the ac don't work as well.
TA - Pro's very affordable, can resell, can remove if selling car, and allows you to adjust the global timing. Cons- only adjust the global timing, Some exp. CEl's with them and IMO makes the front of the engine looked cluttered
Handheld programmers - Pros- can adjust just about anything. Cons - if you only run a certain setup a chip may be a better choice.
But if I were spending your money, U/d's, handheld, gears, offroad, and you'll have a good start.
Not to hijack the thread, but since you're talking about gears, what kind of a difference do 4.10's make in driveablility and mileage for our cars? I had a '94 GT with 3.73's and I hated the mileage and the driveability.
You hated 3.73's in a 5.0? Man those are my favorite gears for a 5.0.
Anyways there is lots of threads that discuss the differences you cna do a quick search and get more info that you prolly want.
In my car I get 24mpg on the hwy I averg 20mpg combined driving and that inculdes a night at the drag strip spraying. I shift between 2k and 2500, which means I'm in 4th or 5th by the time I'm across the average 4lane intersection. The car cruises comfortable at 75-80 getting the above mileage. 90mph is 3k with the 3650 5spd 5th gear ratio. Only real downside is 4th tops out at about 108-110 ish. And 5th doesn't pull all that great at those elevated speeds. Now as for driving they're easy you pretty much have your choice of taking off in 1st which really gets the car moving, 2nd which feels about like the stock gear and 1st or 3rd gear which takes a lil clutch riding to get moving but not alot. Only real downside is wet roads, I find it is easier to take off in 2nd not that first is uncontrollable actaully it is very controllable but when I do the upshift to 2nd it tends to get a lil loose. I'm not a suspension guru but I'm thinking it's the unloading and reloading of the chassis coupled with the gear multiplication.
