  • 1994 - 1995 Specific Tech
U Joint Replacement
  • Thread starter Thread starter Josh94gt
  • Start date Start date Sep 2, 2005
J
Josh94gt
243
Gilbert, AZ
Sep 2, 2005
  • Sep 2, 2005
I'm pretty sure I have a bad U Joint. How much is this gonna cost for just the parts, and how much if I have a shop do it? From what I've heard it's not hard to fix - any pointers???
-josh
94 Cobra 5.0
114
Ft. Riley, KS
Sep 2, 2005
  • Sep 2, 2005
u joint
not hard at all. just did one on mine and it cost me 14 bucks from advance. common hand tools can be used to take them out. needle nose pliers for the small clips and if you have a c-clamp it would make life very very easy. if not a socket about the same size as the u joint itself can be used with the proper amount of motivation and a big enough hammer
HISSIN50
34
129
Sep 2, 2005
  • Sep 2, 2005
Parts stores loan out Ball joint presses, which can be used for U-joints (it is a big C-clamp with adapters). I have bent up regular clamps on bad joints.
It is not hard to do. Be sure to index all parts of the DS before removing or taking it apart. You can also do the joint with the shaft in the car (that is how I do them).
Good luck.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Oct 24, 2006
  • Oct 24, 2006
Bring back from the dead: What is a good quality brand U joint? Advance carries Neapco Universal Joint (Bruce Force heavy duty) or GMB U-Joint (Performance). I just accuired a FMS D/S and before this goes in I'm swaping out U joints.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 24, 2006
  • Oct 24, 2006
Spicer.
Parts stores only seem to carry cheap greaseable ones.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Oct 24, 2006
  • Oct 24, 2006
Were can I find Spicer?? and what about Lakewood??
C
click
142
  • Oct 24, 2006
I was actually just about to go down to my local parts store and pick up two u-joints. Cause when I come to a stop no matter if i'm in a gear or neutral, i get a noise that sounds like you are shaking a spray paint can. I looked at my front joint and there is A LOT of play between the cap and the yoke. So figured it's time to change them both.
All power lost at crank
  • saf_blu302
  • Mar 7, 2026
1994 - 1995 Specific Tech Mar 12, 2026
General karthief
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
Rear Decklid Finish - Lost Gloss
  • 120rir
  • Oct 1, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 1, 2026
120rir
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
