u joints or torque boxes?????
stangincoupe89
someone please help!! when i go into reverse or forward there is a very loud bang coming from the rear of the car. its sounds like someone is taking a hammer and banging the frame with it. cant figure out what it is. i looked under to see if anything is loose but everything seems to be in order. could it be the u joints or torque boxes? please help!!
1989 coupe--306 gt40 heads(p&p) trick flow upper and lower--etc...all the extras..
Stick or auto?
If an auto, check motor and trans mounts (good to do on a stick, but more-so on an auto).
Did you check the U-joints and the DS-to-pinion flange bolts yet?
If you get underneath and take a look, by observation and banging/pulling on stuff, you should be able to figure it out.
Good luck.
