ugh more headswap
93GTosu
183
well im STILL putting my P heads on...working a few hours when im home for the weekend. I'm getting the gaskets cleaned off and wow...does it ever really come "clean?" i mean there isnt any gasket left anywhere, just a very thin film that seems to come up in places i already went over.
also, lets say someone "accidentally" rotated the motor a little while the distributor was pulled. this would completely defeat the purpose of me marking it before i pulled it right?? so how would i go about putting it back correctly? (talk me through this ok?) TDC is when the #1 piston is at its highest right? and thats also when the rotor on the distributor points at #1? so could i just put the #1 piston at the top and then drop the distributor in pointing at #1? then i'd either be 180* off or right on right? and THEN set the timing once i get the car started and running ok??
dont be afraid to tell me i'm dumb as hell :p just as long as i put it together correctly
You'll want to get it all off the block, down to bare metal. Your timing procedure also sounds correct. Make sure you know which is cyl. #1, I think its the passenger side front and your firing order.
you're in luck, I just got done getting my car running and had the same issues. You'll have to adjust the rockers anyways, so don't worry about where the distributor needs to line up for the time being. Just go about the correct rocker install procedure then intake ect before you put the distributor back in.
The procedure I went with was to keep all the spark plugs out, then crank the motor over until I felt compression in the #1 cylinder with my finger in it. (The first time I confused suction for air pushing out, so distributor was 180 off.) But you can stick a wire in the spark plug hole and verify the piston is up. Then check the balancer fand make sure the timing mark points to 0 degrees and then you're at top dead center. From here you can stab the distributor in any position you want, as long as it's pointing to where the #1 spark plug wire is when you install it or thereabouts. If the car does't start, theres a good chance you're 180 off and just restab. God knows it took me like 20 times to find out how stupid I was to begin with.
That gasket material is a b**** to get off. Don't skimp on it, as much as it is a pita, it should all come off to bare metal. Carb cleaner and a good terry cloth with a little pressure help to dissolve some of the gunk off too.
Good luck:D
