Uhmm.. broken o2 sensor
  • Thread starter Thread starter Blakthorn
  • Start date Start date Apr 20, 2006
Blakthorn
299
US
Apr 20, 2006
  • Apr 20, 2006
crawled under the car to check things out and noticed my passenger side o2 sensor is plugged into my upr x pipe....but guess what...the other end is cut and not plugged into the car..i always skimmed over this because i just checked the x pipe to see if they are there
so for about 4 months i have been running the car with only 1 o2 sensor, i have an 87 so no check engine light and i was clueless
What happens when only 1 sensor is working, any negative affects to the car?
D
DeVus1
400
P-Town, Va.
Apr 20, 2006
  • Apr 20, 2006
Probably not. The older engines are more forgiving with things like that.
D
Daggar
3,902
  • Apr 20, 2006
you may be stuck in open loop and not even have realized. What's your gas mileage been like?
Blakthorn
299
US
Apr 20, 2006
  • Apr 20, 2006
Daggar, whats open loop? My gas mileage is average, leaning towards above average slightly..
D
Daggar
3,902
  • Apr 20, 2006
Open loop is the mode the EEC goes into during startup and when cold. The car runs on preset fuel tables and takes input from a very few number of sensors. A lot of things have to be "right" in order for the EEc to go into closed loop and vary spark and fuel tables to run as effiently as it can. Something as small as a bad ECT sensor or coolant temp sensor can cause the EEc to remain in open loop. What I don't know, is if having only one of two 02 sensors operating correctly will cuase that condition. If the motor is running strong and not killing you in gas then leave it. If you ever go to hook that sensor back up, it will likely need replacing. running that long wihtout a preheater in teh exhaust stream has surely ruined it by now.
Blakthorn
299
US
Apr 20, 2006
  • Apr 20, 2006
i plan to replace them both, what should i expect, if anything?
D
Daggar
3,902
  • Apr 20, 2006
If anything (assuming the EEC isn't able to do it's best with just one 02), you may see in increase in mileage.
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Friday at 3:09 PM
2000xp8
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
