undecided about intake for dart 363 8.2 deck engine build
just4bob50
504
Pa.
Im sure that this question fall entirely into tech, but Im not certain Ill get what I looking for from the talk section.
After talking some more with Rick 91GT at RNH, I've decided on going with a Dart based 363 stroker. We will be using TFS TW heads with 1.7 RR's. Ive decided to go with a custom cam and will be looking for a 6500 rpm shift point. The heads are stock now but, will probrably get some port work done to them. Im not sure as to what intake to go with yet, but that will have to be sorted out before the cam can be ground. 2 choices so far are the EDDY RPM 2 and the Holley Systemax. I would like to have an EFI intake that will flow to 6500, but not give up alot of bottom end since my car will see more street than strip. Im selling off my GT-40 intake and Powerdyne charger, to help fund this build. I will be going (NA) at first on this motor but I will have a 9.5:1 compression so boost can be added later. I hoping for around 400rwhp NA. Any one with opinions on intakes and why please chime in.
TFS R or a victor efi manifold. You will have PLENTY of low end with that 363". The tfs R is more of a direct bolt on, the victor may need milling and/or port matching. I personally run a TFS R on my twisted wedge headed RNH built 347 short. I shift around 6,800.
