Under Drive pullies
  • Thread starter Thread starter 89CobraGT
  • Start date Start date May 15, 2007
89CobraGT
113
Winnipeg manitoba
May 15, 2007
  • May 15, 2007
hey... So I was going to install my underdrive pullies but I'm thinking I'm gonna have some charging issues with my electric fan and stereo it pulls alot of power. I was wondering if I can just install the pully for my water pump and crank.. Will my car still run ok even though the pullys dont match I also have power steering but Ive never seen a pully for that... anways any input would be apperciated..
thanks
Bullitt347
I have been doing it wrong this whole time
4,064
3,138
204
Middle of Maine
May 15, 2007
  • May 15, 2007
You can run just 1 of the underdrive's if you would like. It depends on whose pulleys you use. I believe Auto Specialties makes an underdrive P/S pulley.
89CobraGT
113
Winnipeg manitoba
May 15, 2007
  • May 15, 2007
soo I can run my crank pully and my waterpump pully?? I'll have t look for the p/s one thanks!!
AnthonyR23
661
Ontario
May 16, 2007
  • May 16, 2007
I would suggest upgrading to new 130amp 3g alternator.. with a overdrive pulley.. if you can't do the alt. upgrade at least get a overdrive pulley for your old one.. mine was about 18.95.
04sleeper
2,674
14
89
Dallas, TX
May 16, 2007
  • May 16, 2007
The best setup for the street that I have found is the 4" underdrive crank pulley, stock water pump pulley and 1 7/8 overdrive alternator pulley.
I do suggest running the 130amp alternator like mentioned.
A good place to source the alternator pulley is here. http://rjminjectiontech.com/?p=7
P
PJB
131
Rotterdam, NY
May 16, 2007
  • May 16, 2007
I used the underdrive waterpump and crank pullies but still had issues with charging when using the underdrive pulley on the alternator even though I upgraded to a 130 amp '94 Mustang GT alternator.
I ended up putting my stock '92 alternator pulley on the higher output alternator.
BTW the fox underdrive alternator pulley is the same size as the SN95 130 alternator amp pulley.
89CobraGT
113
Winnipeg manitoba
May 16, 2007
  • May 16, 2007
I have a 100 amp alternator it works pretty good I just wanted to know if I could keep the stock pully alternator pully thanx
AnthonyR23
661
Ontario
May 16, 2007
  • May 16, 2007
Well if you decide to get a high powered amp or electric fan and you notice that your voltage is too low... remember that overdrive pulley... it's pretty tiny... I'll send a pic...
P
PJB
131
Rotterdam, NY
May 16, 2007
  • May 16, 2007
Basically putting the stock alternator pulley on the higher output alternator is overdriving it since the stock pulley is smaller.
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
  • dan50
  • Jul 18, 2026
dan50
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
9
New from northern MN
  • 91firecracker
  • Apr 19, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 19, 2026
