- Feb 16, 2013
- 30
- 0
- 7
I just ordered a custom fiberglass hood for my 1991 convertable at http://www.latemodelrestoration.com/item/CER-101/1987-93-Mustang-Ram-Air-Fiberglass-Hood-15-Rise
My question is... will I need to put on a "Under Hood Insulator" like the one that's on the original metal hood? Or will the fiberglass hood withstand the extream heat that's put out from the custom headers?
HISTORY:
I'm having an overheating issue so I replaced the mechanical fan with an electrical dual fran from a contour. (Obviously I've also upgraded my altenator to a 3g as well) My fans are powered though some relays... yada yada yada.
My 40amp relay (mounted close to the hood on the passanger fender side) burnt out (Melted connector) at the power wire to the fans. I think this is a combination of the headers putting out so much heat and not having a proper ventalation system, hence the ordering of the new hood.
EVERY wire is running hot to the touch, including the possitive battery cable at the battery connection. The aforementioned relay can't be held for more than a couple of seconds without getting burnt.
The overheating is somehow causing battery drain. In other words, when the car gets to hot (3/4 to max range on temp gauge) and I shut it down to prevent damage I can't start it again without a jump. Is this an isolated problem or is it all connected to the heat under the hood?
Sorry for the lengthy post but I wanted to ensure you guys had all the info. Thanks
HISTORY:
L8trquote="MikeH686, post: 8728725, member: 179793"]When you did the 3g did you up the power wire coming off of the alternator or did you reuse the black and orange wires?[/quote]
