Undercoating
  • Thread starter Thread starter 66mustangg
  • Start date Start date Dec 30, 2005
66mustangg
59
Westchester, NY
Dec 30, 2005
  • Dec 30, 2005
What type of undercoating would you guys recomend....powder coating or a rubberized under coating or like anything else???
H
HHStang
566
Coastal SC
Dec 30, 2005
  • Dec 30, 2005
Most either paint, and/or use the rubberized stuff. Not many powdercoaters that I'm aware of. It really boils down top what kind of car you are looking for. Driver, show, etc.
66mustangg
59
Westchester, NY
Dec 30, 2005
  • Dec 30, 2005
Im probably going to go with POR-15 Rust Preventive Paint and CHASSISCOAT BLACK over that. HOw much paint am i going to need to do the whole undercarridge??
68converted
772
Colorado
Dec 31, 2005
  • Dec 31, 2005
One Qt did the entire underside, engine bay and trunk. Qt 2 was used about 1/2 way when I did my rear axle and the interior.
Something to think about... when I scraped the entire car, any spot that had the petrolium based undercoating or seam sealer was rust free. I realize you would not want to use undercoating in the engine bay but you should use it just about any place else you can. At least if it is not a show car, Then a sweet coat of paint would apply. Use Por's metal ready on any part or place you get to bare metal. And remember, Por15 is only as good as the prep work. ZERO oils, grease, or dust. Take your time and it comes out great. Another tip- pull all the body crack and joint sealer out, Por15 then reapply the seam sealer. Your going to top coat anyway, and this way you can get total protection.
Tip for the seam sealer, fill in the crack, then use a wet piece of t-shirt to smooth it out, finger works well too.
Too much coffee, too much sleep, and this is what you get. Happy New Year!
68converted
772
Colorado
Dec 31, 2005
  • Dec 31, 2005
Sorry, remembered something else. Use a plastic turkey baster and the cheapo tupperware or hard zip lock food containers to store the liquid you are painting with. Trust many of us on here about that one. If you get some on the seal of the rim and close it, the lid is not coming off again.
66mustangg
59
Westchester, NY
Dec 31, 2005
  • Dec 31, 2005
thanks man ill prolly go with the 1 qt thanks for all the tips
75 mustang II
109
  • Jan 1, 2006
Ive used por 15 on alot of my projects,If your not going to use for awhile keep it in the fridg.I use suran wrap under the lid to keep the lid from permanently sealing.Use rubber gloves and if you get some on you remove or you will wear it for a few weeks.Did my 69 charger 6 years ago and it looks as good as the day it was done.
Cannoball888
320
Gainesville, FL
Jan 1, 2006
  • Jan 1, 2006
What is best for topcoating the Por15, rubberized or standard chasis paint?
75 mustang II
109
  • Jan 1, 2006
Cannoball888,Theres a topcoat that por-15 sells.I used ruberized undercoating.Por-15 cannot be exposed to uv rays for any length of time.Once it is dry you could topcoat with any paint.
SOLD AFS 2003 Cobra Replica Wheels for sale
  • 02GTOG
  • Aug 29, 2026
  • Wheels Tires Brakes
Wheels Tires Brakes Sep 18, 2026
02GTOG
M
Kind of a unique problem
  • MadMatt7
  • Oct 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 15, 2026
rednotch
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 3:55 AM
manicmechanic007
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
J
5.0 ignition wiring help
  • Jetscat7
  • Nov 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 25, 2025
