underdrive pulley
  • Thread starter Thread starter lpraider50
  • Start date Start date Oct 17, 2011
L
lpraider50
18
  • Oct 17, 2011
Just ordered one to throw in my 97 gt.
anyone1 ever do it before?
how long did install take and how was your cars performance change?
evolucion311
236
Oct 17, 2011
  • Oct 17, 2011
If you are using anything other than Steeda or other high quality pulleys that are a one piece harmonic balancer and pulley assembly TAKE IT BACK.
Don't waste your money on piggy back pulleys. They are a pain in the ass to install and have a bad reputation for wobble and setting a crank position sensor code.
Do it right or don't do it at all.
I did Steeda UDPs and haven't had any problems from them but did notice my alternator voltage dipped just slightly so my amps cause a slight flicker when turned up loud.
A stiffening capacitor fixed this.
N8Dogg98
3,872
238
184
MN
Oct 17, 2011
  • Oct 17, 2011
I've had MAC piggyback UDP's on my car now for 7 years and about 70K miles. My car runs just fine, and the install (while annoying) wasn't terrible. Do you have personal experience with UDP's causing "wobble and setting a crank position sensor code", or is this just another internet rumor?
OP if you get the piggyback style, make sure you soak the pulley's in a pot of hot boiling water for a little bit before screwing them together. As far as performance gains, it was really hard to tell a SOTP difference. However, they only cost $99 so even if they did nothing I wasn't out much money
fiveoho
1,958
TN
Oct 17, 2011
  • Oct 17, 2011
i also have the steeda pulleys. very happy with these. install wasnt too bad but not super easy either ( balancer was a bit challenging ). i admit, i bought these because of the piggyback rumors. i personally have had no experience with piggyback pulleys but there are several guys out there like nate that have ran these with 0 issues.
consider this - if your car is higher mileage or your stock balancer is in bad shape, spend the extra money to get quality pullies and a new balancer as well.
Sonic04GT
844
West Palm Beach, FL
Oct 17, 2011
  • Oct 17, 2011
Same here. I heard enough rumors to convince me to go the "right" way. Can't go wrong with a Steeda product, especially since they worked with Ford to design the balancer with the correct damper characteristics.
L
lpraider50
18
  • Oct 17, 2011
i was told that if i install the pulley ill get a more mid-top speed. Is that true?
T
Engine Removal of Steeda Underdrive pulley
  • THughes
  • Jun 30, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 4, 2026
Dino Dino Bambino
Engine Underdrive pulleys
  • Mindseye007
  • Feb 1, 2026
Fox 5.0 Mustang Tech Feb 14, 2026
Willybill32
CHANGING BRAKE PADS
  • Scwhitten
  • Jun 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 12, 2026
nickyb
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
