  • SN95 4.6L Mustang Tech
Underdrive Pullies
  • Thread starter Thread starter madstyle1
  • Start date Start date Nov 11, 2004
madstyle1
21
  • Nov 11, 2004
im about to install steeda underdrive pullies just wondering if i have to buy a new belt.... got a 2004 GT with 4000 miles on it... should still be good right??
dsg_gt2004
423
Georgetown,SC
Nov 11, 2004
  • Nov 11, 2004
im sure it is...i never heard anything about a new belt..so my answer is use the stocker unless it looks cracked or worn WHICH i highly it will
myponyrocks
I have more billet on the Stang than most women ha
Apr 18, 2004
1,219
Nov 11, 2004
  • Nov 11, 2004
I have the Steeda UD's and it uses the stock belt. The stocker is still in great shape (30k+ miles)
WhiteDevil69
518
Tucson, AZ
Nov 11, 2004
  • Nov 11, 2004
No need for a new belt, i had 13k on mine when i did mine and there was NO sign of wear, let alone a crack or problem. The old belt will fit perfectly with the new pulleys.
mcmmotorsports
689
Danbury, CT
Nov 11, 2004
  • Nov 11, 2004
Any need to apply silicone to the crank pulley when installing the Steeda's?
I heard others having to do this to avoid an oil leak and wasn't sure if this is needed with the Steeda Pullies.
CManT1914
3,172
Killeen, Texas
Nov 11, 2004
  • Nov 11, 2004
I have never heard of having to use silicone to seal an oil leak on a pulley. That doesn't make sense, there's no oil running through a pulley. I did pulleys on mine and the factory belt fit fine. But it started squealing some after (it had around 94,000 miles on it at the time) so I went ahead and replaced it with another factory size belt a couple weeks later.
GTvert01
636
West Plains, MO
Nov 11, 2004
  • Nov 11, 2004
No, it is not needed.There is a small amount that comes out when you change pullies,but no leaks.Also, as stated before, it uses the stock belt.A pretty straightforward install.
myponyrocks
Apr 18, 2004
1,219
Nov 11, 2004
  • Nov 11, 2004
BULL! The Steeda instructions state that you should put a bead of RTV (It may have been silicone) in the keyway BEFORE installing, this IS to prevent a leak or something... not sure BUT YOU HAVE TO DO THIS
GTvert01
636
West Plains, MO
Nov 11, 2004
  • Nov 11, 2004
ummm....have to?I have been running mine for over a year and no leaks.It may be a good precautionary measure.
CManT1914
3,172
Killeen, Texas
Nov 11, 2004
#10
  • Nov 11, 2004
  • #10
Sorry, but I agree with GTvert01, I have never heard of having to use silicon to seal anything up. Instructions say a LOT of things, but a lot of them aren't necessary.
topgunz_1
100
Louisiana
Nov 11, 2004
#11
  • Nov 11, 2004
  • #11
spoken like a true man!
myponyrocks
Apr 18, 2004
1,219
Nov 11, 2004
#12
  • Nov 11, 2004
  • #12
Apply a dab of high temperature silicone sealer (gasket maker) to the keyway slot on the underdrive crankshaft balancer pulley. Line up the keyway and install the pulley. Use the longer bolt supplied to pull the balancer onto the crankshaft. DON'T TIGHTEN THE BOLT ALL THE WAY. ONCE THE PULLEY IS MOSTLY ON, REMOVE THE LONGER BOLT AND INSTALL THE FACTORY BOLT. Torque factory crankshaft bolt to factory specifications.
http://www.steeda.com/instructions/pulleys.htm
Ok that doesnt say why... still searching
When installing the Steeda crank pulley, notice that they include a longer bolt to help get the pulley started on the shaft. Before you put the new pulley on, put a dab of silicone on the crank keyway and some oil on the pulley oil seal area. The silicone prevents any oil leaking out through the keyway and the oil will ensure you don't damage the seal when tightening the pulley down. Make sure you remove the longer bolt before the last portion of cinching down the pulley and replace it with your new, normal length bolt.
http://www.****zot.com/engine.htm
For some reason URL gets edited, I dont think its a badd word?
Ok its listing oil as the only reason. Sorry I was an ass, was in a bad mood earlier. Any way, its always better to be safe than sorry, especially when safe only costs 4 bucks or so at most, assuming you dont have access to any for free. People shouldnt discourage something that may do nothing, but has been reported to stop something bad from happening.
CManT1914
3,172
Killeen, Texas
Nov 11, 2004
#13
  • Nov 11, 2004
  • #13
True that.
GTvert01
636
West Plains, MO
Nov 11, 2004
#14
  • Nov 11, 2004
  • #14
agreed
J
jbrown
393
Tallahassee, FL
Nov 11, 2004
#15
  • Nov 11, 2004
  • #15
the steeda instructions state to use a small amount of silicon or rtv on the keyway slot. Why not just do it if youre going to install them it could possibly save you time and headaches in the future. The mechanic who put mine in almost forgot but I reminded him, no leaks that I know of. BTW hope you have good air tools and get a loaner pulley puller from the auto part store.
myponyrocks
Apr 18, 2004
1,219
Nov 11, 2004
#16
  • Nov 11, 2004
  • #16
OOOH good point, the autoshop I went to had to rig something cause the steeda bolt is different than any puller he had when he was reinstalling
T
Engine Removal of Steeda Underdrive pulley
  • THughes
  • Jun 30, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 4, 2026
Dino Dino Bambino
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
Airaid reduction sleeve?
  • BriansNSane
  • Dec 20, 2025
SN95 4.6L Mustang Tech Dec 20, 2025
BriansNSane
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
