Got all my rings on my pistons except for one piston has an uneven 2nd ring land. I can get the ring on and it's fine on one half of the land, but the other side of the land apparently isn't even and the ring won't slide in and out of the land. I've tried sanding the land w/ sandpaper a little bit, but it hasn't helped so far. Any ideas? I did clean all of the grooves w/ a groove cleaner.
I did break one 2nd ring and ended up having to use one of my old ones since I doubt you can buy "one" piston ring. The old one should be fine, I suppose, since it wasn't damaged.
