update on motor stumble
  • Thread starter Thread starter 65fastback2+2
  • Start date Start date May 6, 2005
65fastback2+2
1,229
Louisville, KY
May 6, 2005
  • May 6, 2005
some of ya'll were helping me about a month ago with a stumble. Well, I got the carb rebuilt thinking maybe that was it, and it wasnt. So now I am gonna go with it is a ignition problem. It has a petronix electronic ignition with a flamethrower coil. Possible maybe water got in the coil or something???? Maybe new rotor and dizzy cap? Though I dont see those causing this big a problem. I already did new spark plugs and new fuel filters.....any ideas?????
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
May 6, 2005
  • May 6, 2005
Have you done a plug reading to rule out fuel?
I doubt your coil has water in it unless the terminal corroded under the boot. For safety against that, its a good idea to put a dab of dielectric grease on all the plug/coil terminals. If your cap or rotor is all grown over, just scrape the crud off with something sharp and/or sand it to get by until you replace them.
Blown4.6
351
Orlando, FL
May 6, 2005
  • May 6, 2005
when does it stumble, under what load.....etc. how bad? I've gone through so much crap trying to solve my stumble problem (which simply turned out to be a bad Demon carb), I'll bet I can offer some advice.
engine:
Carb:
base timing:
under what laod does it stumble:
what rpm:
will it do it at cruise too?:
will the stumble go as far as to stall the engine?
Jonstantine
487
Oklahoma
May 7, 2005
  • May 7, 2005
i dont think a carb rebuild would necessarily fix a carb related problem
it could still be out of tune for your car's setup
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
  • brandyn200
  • Jun 20, 2026
AeroCoupe
F
1986 mustang no start
  • foxyjamss221
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2025
foxyjamss221
F
Engine Misfire below 3K RPM
  • foxbodyclark
  • May 25, 2025
Fox 5.0 Mustang Tech May 31, 2025
General karthief
J
Hello all, I have returned from a hiatus... Update and Questions
  • JackH
  • Aug 13, 2025
1974 - 1978 Mustang II Talk & Tech Aug 15, 2025
JackH
J
