- Apr 9, 2002
- 1,644
- 17
- 59
Ok guys..
Fixed that exhaust leak from my headers, New KC clutch, 3.73 gears with some diff upgrades, and changed rear main seal!. Now the questions
, My car sounds 100% better than when I had the leak (sounds like a mustang now), I'm not so happy with the gears though!, I don't feel much of a difference, did'nt really test it out to the max yet because I wanna break in the clutch and gears properly. I also ditched my bosh spark plugs and went back to Motorsport's (ford recomendations), I just need to swap the wires and ditributer cap for some ford racing ones. My compression was at 125psi to 115psi.
Now I'm still missing some power!! What can I do next to see what the problem is?..I know when I took out mu h-pipe It was BLACK inside, If I buy an adjustable fuel thingy, and make it run less lean. Can this cause lose of power??...Thanks guys!
, My car sounds 100% better than when I had the leak (sounds like a mustang now), I'm not so happy with the gears though!, I don't feel much of a difference, did'nt really test it out to the max yet because I wanna break in the clutch and gears properly. I also ditched my bosh spark plugs and went back to Motorsport's (ford recomendations), I just need to swap the wires and ditributer cap for some ford racing ones. My compression was at 125psi to 115psi.Now I'm still missing some power!! What can I do next to see what the problem is?..I know when I took out mu h-pipe It was BLACK inside, If I buy an adjustable fuel thingy, and make it run less lean. Can this cause lose of power??...Thanks guys!
