Fox Upgrades
Just bought an 89 Fox, curious as to what I should upgrade first. Any suggestions?
Every one will probably say to get gears. I have 355 in mine and they are nice. My old one had 373s and I planned on putting 410s in my old auto 95 but never got around to it. Is it a 5 speed or auto?
Even though it wont make you faster, short throws make the car fun to drive. I recently changed out my old worn out hurst shifter for a pro 5.0 and the firm and notchy shifts makes the transmission feel "solid". I got mine used and you could probably get one for cheap too.
Right on right on. It's a 5 speed
Street is for daily driver type builds....strip would be drag car....mild would be near stock. The first thing I usually do is decide what purpose I need the car to perform in. Suspension set ups and spring rates differ between the three. Anytime I buy a new used car the first thing I do is change all the fluids....antifreeze...oil...power steering....rear diff. and trans...depending on mileage. Upgrading the alternator to 3g is a great first mod. Full length subframe connectors with seat brackets is also a great first mod. Everything else really depends on what you want out of your car.
I'd go with 373s. I wish I would of went with those. Also look up heads, cams, and intakes for these cars.
For heads you could look into used explorer/gt40 heads. These are essentially the same heads of 93 cobras and can be found at junkyards for cheap. For more power you could look into new aluminum heads like sve heads from latemodel restoration or trickflows heads. I hear alot about afr heads too.
For intakes you could again find the explore/gt40/cobra intake at a junkyard or you could look into trickflow, holley, or edelbrock intakes.
For cams you can look into the "alphabet cams". These are ford racing cams. They have an e303, b303, f303, ect.
trickflow and anderson also have cams you look into.
Also you could look into headers. You could get short tube or longtubes. Longtubes are supposed to help with torque but require more work to fit them in sometimes.
Hopefully all of this can get you looking in the right direction so you can decide what you want!
Reactions: Steven Pech
I feel you man, speaking of the alternator, I just put in a new battery and the meter is still reading in the red. Could it be the alternator?
Along with the subframes I would reinforce your torque box. The previous owner ripped mine out with drag radials and that was not a cheap fix... Reinforce it now for insurance!
LMR also offers a Stangnet members discount. 6% off. Go to the front page of this site and look up vendors. Find late model restoration and the discount details are in there. Also word(s) of advise-concentrate on chassis reinforcements,brakes,suspension, etc first before going for more power. These cars were lacking in those areas with stock level performance. Adding power just increases the "problem" areas.
