someone told me that becuse my car has an internal voltage regulator then maybe the alt will pass the test at autozone but the regulator could be not working properly.
so. i went to autozone and bought a new alt to try out. i was gonna take it home and change it at my house.
the thing is though when i went to start my car, it wouldnt start. so luckily i had some tools with me and i changed my alternator right in the parking lot while they recharged my battery inside.
then, like a douchebag, when i went to put my battery back in i had it the wrong way so i wound up connecting the positive cable to the negative terminal and vice versa. i guess i wound up blowing some fuses doing this cause now my radio doesnt work and neither does my speedometer or clock. i also shocked my hand slightly.
right now its raining and i dont feel like going outside and pulling fuses. but i drove all the way home without having the red battery light come on and the battery meter voltage is quite high so hopefully i fixed the problem while only causing a newer lesser problem of changing fuses.
