Upgrading heads on 04 GT
blow it dude
01Steeda said:
kewl.. i was just wondering, i just talked to my engine builder and gunnar @ patriot. Looks like with the right gaskets and the piston being 5 in the hole.. i should be @ 9.6:1 or with factory gaskets and 0 10.9:1. So I gotta decide wether I am gonna get a blower anytime soon.
dude stick to 10:1. you can still blow the hell out of it. propper cam to bleed low rpm's cylinder pressure, VERY good intercooling (air-water), and engine managment to handle all situations.don't piss away output because of misnomers about C/R. sure pre-ignition happens, but there are factors you can control. reflective coatings, smoothed chamber surfaces, cool plugs, a slightly rich mixture to quench hot spots, etc. intercooling overkill. that's the ticket.
No, bad advice. You need to build the engine for the applications. If you already had a built engine, then that would be one thing. If you're building an engine, build it properly. It would be foolish to do otherwise.
come on dude. humor me.
he can run higher compression with the proper matched cam, and other components.
i wouldn't want to melt a piston. for a supercharger i am more likely to keep most of the compression.
the roush blower for the 5.4 3v doesn't require a lower C/R.
hotmustang331 said:
Another guy on here has stg 1 VT cams and MPH STG 2.5 heads (flow MUCH more than patriots...like 20CFM....thats alot on the 2V world lol) and puts down 310 or 311RWHP.
That's probably me, I have a Steeda CAI, Accufab T/B & Plenum, Steeda Intake Spacer, UDP, TA, VT Stage 1 Cams, Bassani Mid Lengths, Bassani X Pipe, Steeda Cat Back, 3:73's, Superchips Tune, MPH Stage 2.5 Heads all tuned by Steeda Autosports and my car puts down 310rwhp and 325rwtq. Prior to the heads and header install and the retune my car made 284rwhp and 302rwtq. With the install of the cams alone and a retune my car gained 33rwhp and 13rwtq.
336RWHP!!
I have a 01 S-281 Vortech Supercharged, 3:73 Gears, Long tube headers, 60lbs Injectors, X-pipe and a custom tune and it dyno'd 336rwhp at the wheels...so there is no way urs is the same with just cams and heads
