R red93fox New Member Aug 25, 2004 41 0 0 Sep 25, 2004 #1 Sep 25, 2004 #1 how do i remove the bushing from the axle housing for the upper control arm?
M mikeflys1 Founding Member Aug 27, 2002 217 1 0 CT Sep 25, 2004 #2 Sep 25, 2004 #2 Oh thats a fun one.....i pretty much beat the **** out of it with a big hammer to get it out. You might try usin like a ball joint press though.
9 92BlackGT Member Aug 4, 2003 182 7 17 Tinker AFB, OK Sep 26, 2004 #3 Sep 26, 2004 #3 I used a drill and drilled the bastards out. Get enough out where it falls apart and the rest comes on out. Makes a mess tho.
PNY PWR New Member Jul 23, 2004 522 0 0 Wichita, KS Sep 26, 2004 #4 Sep 26, 2004 #4 Use this tool from MM, it's removes and installs the bushings correctly. Comes with good instructions and even sets the depth right when you reinstall. Made that job so much easier. http://www.maximummotorsports.com/rucabushing.asp
