upper control arms????
  • Thread starter Thread starter jimsstang91
  • Start date Start date Dec 8, 2005
jimsstang91
101
  • Dec 8, 2005
who sells just the upper control arms?? i looked in jegs and summit but they sell upper and lower as one.
jammer84_03
468
  • Dec 8, 2005
front or rear?
jimsstang91
101
  • Dec 8, 2005
sorry rear
jammer84_03
468
  • Dec 8, 2005
steeda offers them, as well as maximum motorsports
W
WilwoodFiveO
108
VA
Dec 8, 2005
  • Dec 8, 2005
i have steeda double adjustable ones
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Dec 8, 2005
  • Dec 8, 2005
The FRPP unit doesn't do anything from what I have read on the forums...
E
emagdnim
391
15
28
Dec 8, 2005
  • Dec 8, 2005
Ford Racing sells nice uppers cheap.
jammer84_03
468
  • Dec 8, 2005
get some fully adjustables.....you'll appreciate it later when you start dialing in the suspension
millhouse
1,985
Simpsonville, SC
Dec 8, 2005
  • Dec 8, 2005
Sure they do...they keep the rear end from binding by using slightly more rigid rubber bushings than stock.
Maximum motorsports has a good write up on their webiste about rear suspension bind using poly busings.
J
jerryD
1,061
Gladstone, MO
Dec 8, 2005
#10
  • Dec 8, 2005
  • #10
metco has double adj. uppers. cost is mighty high though.
Maryland Stang
1,656
30
39
Greenville, NC
Dec 9, 2005
#11
  • Dec 9, 2005
  • #11
I'm going to use reinforced FRPP uppers with Steeda spherical bushings.
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Dec 9, 2005
#12
  • Dec 9, 2005
  • #12
Ive got steeda ones for 110 im waiting to install them. They arent adjustable but they are strong as hell.
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Dec 9, 2005
#13
  • Dec 9, 2005
  • #13
i'll sell you a pair of lakewoods, $75 plus shipping. they are brand new still have the box they came in. PM me if interested
A
AZ93GT
34
Gilbert, AZ
Dec 9, 2005
#14
  • Dec 9, 2005
  • #14
I run UPR Double adjustables in my car with spherical bushings. They were a piece of cake to install and I'm really happy with them.
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Dec 9, 2005
#15
  • Dec 9, 2005
  • #15
The FMS uppers are a waste of money, i got them years ago, they are just a glorified stock replacement, not worth the trouble of the install. Same with the cheap set of steeda, that look like stock.
Double adjustable uppers are the way to go. Steeda has a set that have a poly bushing on the car side, which are good for a DD. Also comes with a new bushing set for the rear side of the car.
I happened to have a set without that bushing, a heim joint in it's place, but my car see's few miles a year it seems.
millhouse
1,985
Simpsonville, SC
Dec 9, 2005
#16
  • Dec 9, 2005
  • #16
Then why would one of the leading aftermarket suspension companies (MM) recommend them?
If you plan on doing more than driving in a straight line...and plan on keeping the stock 4-link suspension setup then they are the logical number one choice.
Poly bushings in general are a bad choice for anything but dragracing...unless they are a multi-piece design that allows proper axle movement.
Here is a nice sight which explains some mustang suspension basics.
http://www.miracerros.com/mustang/t_suspension.htm#Rear
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Dec 10, 2005
#17
  • Dec 10, 2005
  • #17
everyone that i have known with the fms uppers had bad wheelhop once they took the quadshocks off, when i put my edelbrock uppers and mm lowers(all solid bushings) the car hookes way better on the street and there is only wheelhop when the ground is cold
Maryland Stang
1,656
30
39
Greenville, NC
Dec 10, 2005
#18
  • Dec 10, 2005
  • #18
Were they still using the stock lowers? Did they change the upper bushings that are in the rearend housing? The only difference between the stock and the FMS uppers is the front facing bushing is twice as stiff as the stock bushing. Unless you do some other work (like the lowers and the rearend housing bushing) you won't notice much, if any difference. It's a package deal.
1968 coupe global west upper control arm template
  • Butchd88
  • Feb 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 12, 2026
Butchd88
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
Clark302
C
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
  • Engine and Power Adder
Engine and Power Adder Aug 19, 2026
Habu135
O
Back in a Fox
  • Osorio299
  • Jul 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 25, 2026
gkomo
