I'm about ready to put on my upper intake manifold, but I haven't figured out where all the hoses underneath the intake go. I'm switching from a stock intake to a Trick Flow Street Heat intake by the way. In this pic you can see that I've installed all the necessary fittings and hoses to the Trick Flow, but I don't know what happens to the smaller brass hose fitting on the top and right in the pic.
In this pic you can see the bottom of the stock intake manifold (most of the hoses have already been removed and swapped onto the new intake).
The fitting that I'm asking about on the Trick Flow intake doesn't exist on the old intake. Rather it is a large threaded opening the same size as the one on the opposite side of it (where the large black hard line threads in). I don't remember if there was anything ever threaded into that opening, or if it was just left open with nothing threaded into it. For the Trick Flow intake, there wasn't a large opening like the stocker, but a small one instead (that's why I figured thats where the brass hose fitting goes in, because it came with the intake and fit perfectly).
My question is should I plug the fitting, or does something connect to it? I hope this isn't too confusing! Thanks!
