Where can I pick up some of this stuff? I have tried Autozone, Advanced, and a couple local parts houses and no one has any. Also is there an alternative lube to use instead of the urethane grease. I was told at one store to use lithium grease.
Lithium grease will work as the main concern is that it has a resistance to moisture, but the stuff that comes with the bushings is usually a thicker consistancy. You should be able to find it at any marine supply store. I'd use the lithium grease as a last resort.
Hey slvrbullit302 did that lube work? I'm currently rebuilding my rear suspension and have all Urethane bushings. Is that lube from Jegs something I should buy?
