when i purchased my car i changed the battery to an optima red top i install batteries at work all day long and the install went smooth but i found that the car had an alarm previously installed on it so after installing it the car would not start i found a small valet switch under that dash reset it and was on my way (i do not have a keyless entry remote). today i changed my oil pressure switch i disconnected my battery to do so and had the same alarm ordeal again except this time i could not get it to reset when i reconnected the battery the windows rolled up and the door chime was dinging without the key in... the car wouldnt start and i could not get the alarm to reset. when i looked under the dash for the first time i found a wiring mess i tried bypassing the valet switch and did nothing but i did find a few inline fuses in the wiring i pulled them one by one got the alarm to shut off and the car started.... i left for work and realize my windows now wont go down..i have absolutly no experiance with alarm systems and want this thing outta my car ! looking under the dash it looks as if maybe the alarm was spliced into some of the engines computer there are a few different modules under the colum, what are these modules? and can someone give me a general idea on how an alarm would be hooked up and what it needs to be hooked into cause i need to rip this alarm system out. its very scary sniping wires around and under that steering colum please help! much appreciated btw im fairly sure the car also had factory alarm the dome light turns on the exterior handle is pulled
thanks: ethan
thanks: ethan
