- Oct 9, 2003
- 968
- 1
- 17
I have stud mount AFR165's (#1402). I called AFR and asked them what and if I could use anti-seize on the rocker stud threads that go into the head and they said it was OK. He said oil, moly lube, or anti-seize, whatever. I installed them with anti-seize and have ran the engine a few hours. Now I see that Trick Flow specifically says not to use anti-seize on these.
Did the tech at AFR not know?
Why does Trick Flow specifically say not to?
Are the rocker stud threads in the AFR's heli-coils or just tapped?
Ultimately, should I clean off the anti-seize and just use oil or moly lube?
Thanks,
Rick
Thanks,
Rick
