  • SN95 4.6L Mustang Tech
use firewall adjuster with stock quadrant
  • Thread starter Thread starter rockyracoon
  • Start date Start date Mar 13, 2011
R
rockyracoon
874
27
49
margate NJ
Mar 13, 2011
  • Mar 13, 2011
Can I use a firewall adjuster with the stock (self adjusting) quadrant ?
Dark04GT
758
62
59
NC
Mar 13, 2011
  • Mar 13, 2011
No it completely defeats the purpose of the firewall adjuster. The whole point of the firewall adjuster is that the point of adjustment is shifted from the stock mechanism to just solely being at the firewall. Therefore you can set the adjustment and it won't have to adjust and move ever again. If you kept the stock quadrant you now have two points of adjustment- this makes your clutch cable worthless to adjust because you now have a fight between two devices and defeats the purpose of the firewall adjuster. Every adjustment you would make would be jacked up in the fight between the two devices and the clutch will be unpredictable. Buy an appropriate aftermarket quadrant if you are going to install a firewall adjuster.
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
2001 SVT Cobra slow return to idle speed
  • phil2001svt
  • Oct 21, 2026
  • SVT Tech Forum
SVT Tech Forum Nov 2, 2026
phil2001svt
Fox Clutch firewall adjuster
  • limp
  • Jul 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 1, 2025
limp
Fuel 1990 installing edelBrock intake
  • Beaker
  • Oct 5, 2026
Fox 5.0 Mustang Tech Oct 6, 2026
A
Replacing stock clutch quadrant
  • Ayden
  • Mar 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 31, 2025
Kabuki_notch
