Using a EFI starter on a Carb'd car
Busted07
I need my gorilla to be about an inch longer.
Nov 15, 2005
Im using a stock EFI starter on a car that i have converted to carb. My question to you guys that have done this is.....
how the hell did you do it?
Im thinking that the stock harness wont work right, and like everything else on the damn car, ill have to modify something.
I took this car apart 4 years ago, and i dont remember what stud on the starter does what. does anyone know if i can just run a hot (+) wire to it ? do i have to have a ground on it?
HELP!
Yep - the starter interlock circuit is academic. Leave it roughly as it is and you should be good.
ok, i thought that when it was EFI, there was a harness or something that had several connectors that went to the back.
so slap a positive wire (cable) from the solenoid to the starter, a few engine grounds and i should be cool, right?
And Hissin, youll have to use smaller words, i was up till 12:15 last night working on this car, and my brain is mush right now lol
Ok use the dispersion-strengthened hafnium excelinide terminals and connect them to the particle excellerator. Make sure that the starter is full of Deuterium/Tritium mix. MAKE SURE there's no power drain into the main particle impeller which will cause the internal confinement fields to be lost, flooding the engine bay with radiation. Oh and connect the shield systems which are composed of highly focused spatial distortions which contain an energetic graviton field which will help prevent any road dirt to get into the starter...
:D
:D
I have friends just like you... those friends are the reason i drink so much :D
