  • SN95 4.6L Mustang Tech
using dex-cool in gt?
  • Thread starter Thread starter warrior86
  • Start date Start date Dec 12, 2005
W
warrior86
18
  • Dec 12, 2005
When doing a coolant drain about 4 months ago i purchased whatever seemed like the best quality extended life coolant at the parts store. Well...it happened to be dexcool. The first time i didnt consult my manual or forums, etc, turns out that im only supposed to use the traditional green coolant. Should i take this prestone gm approved dex cool out ASAP?!? Does anybody use this in their stangs and have good or bad experiences? I know a guy that used dexcool in both his saleens for the past two years.
any info or suggestions would be greatly appreciated.
sgarlic
3,085
Dec 12, 2005
  • Dec 12, 2005
I'd take it out.. I probably wouldn't lose any sleep over it, but next chance you have to flush it, make it a point.
I've read that it's incompatible with regular coolant, and can decrease your regular coolants ability to prevent corrosion and contamination.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Dec 12, 2005
  • Dec 12, 2005
blackfang
1,290
Richmond, Va
Dec 12, 2005
  • Dec 12, 2005
I hate Dexcool as over time it creates a goop inside the hoses and is a little harder to clean out verse the 50/50 green coolant.
Yeah 100-150k coolant is nice for us dealership people to ease the maintenance for a customer on the car. However, it isn't always helping the system after 75k with that crap in there.
DropTopPony
Noob Slayer
2,570
south jersey
Dec 12, 2005
  • Dec 12, 2005
That stuff sucks! It would get caked up sorta gunked up in my Blazer. Was a bitch to flush out.
Outlaw97GT
234
Redneckville, Tx
Dec 12, 2005
  • Dec 12, 2005
Do not mix dex-cool with any other antifreeze, it will gel up!
silvergt2001
48
Houston, Tx
Dec 13, 2005
  • Dec 13, 2005
its also made for newer style gm radiators manufactured with certain materials so I've heard.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Dec 13, 2005
  • Dec 13, 2005
basically to get all the dexcool out, you have to flush the system multiple times. we had a buick come into my work that had a mix of green and dexcool and the owner wanted dexcool. we had to do a full flush with just water 2 times to get the fluid to come out clean. that was after using prestones radiator flush adn cleaner. we then filled it with dexcool and all was well.
on a similar note, we had someone come in asking for a brake eval because they had a soft pedal. apparently Jiffy Lube had put power steering fluid in the master cylinder. the people thought we could just flush it out. if anyone knows anything about brakes you know what you have to do when you mix anything else besides brake fluid in a master. all the calipers, lines, hoses, master, ABS unit, all ABS solenoids, brake booster had to be replaced.
sgarlic
3,085
Dec 13, 2005
  • Dec 13, 2005
The sad part is, the owner probably will never get any cash back from the Jiffy lube place, and the guy who did it probably still works there.
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Dec 13, 2005
#10
  • Dec 13, 2005
  • #10
As long as you flush your system completely, using Dexcool will not hurt anything. Probrem with Dexcool is that most people don't flush the system good enough, and you'll end up with gunk.
I was told by Ford tech as rule of thumb:
U can use Dexcool on place of green stuff as long as flushed completely.
But you can NOT use green stuff to replace Dexcool exuipped engine.
Only thing that Dexcool is better then green stuff is that it last longer. It doesn't cool any better then green stuff. SO i would keep greeen stuff.
blackfang
1,290
Richmond, Va
Dec 13, 2005
#11
  • Dec 13, 2005
  • #11
Jiffy Lube and walmart were my best customers. They bought a few engines and had us put them in for their customers
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Dec 13, 2005
#12
  • Dec 13, 2005
  • #12
COOLANT CONFUSION: It's Not Easy Being Green . . . or Yellow or Orange or....
Found this little write up and thought it might be helpful to some....
With so many different coolants out there, it's important-make that essential-to know what's safe to put in where, and when.
Lift the hood of a new Ford vehicle and you're likely to see a yellow coolant in the overflow jug and an interesting label on it. In pictorial language it says "Do not use orange coolant; yellow coolant is okay."
Sounds pretty straightforward, right? It isn't. Lift the hood of another Ford product (in this case, a Taurus with the pushrod V6) and you'll see that same label, but the jug contains orange coolant. Wait a minute. Something clearly is very wrong. It cautions "don't use orange," but the factory-installed coolant is orange.
Lift the hood of a Chrysler product and you'll see orange coolant in the jug and a "special engine coolant only" warning on the cap. Isn't DexCool the special coolant, and isn't it orange? Yes to both questions, but Chrysler Group says don't use DexCool in its products. It's confusing, to say the least.
The basic answers to what coolant to use where, and when, are pretty simple, but when you go past that, you're getting into some pretty complex territory. And you have to know what coolant you're dealing with to be sure you're doing no harm.
Longtime MOTOR readers know that the color of the coolant dye really is meaningless. Dye should help you spot a leak, but that's about it. But with these seemingly contradictory warning labels, you really need a basic understanding of what's been happening with coolant formulations and colorings.
You may remember that about 93% of most coolant is ethylene glycol, another few percentage points are water and/or a solvent to keep rust/corrosion inhibitors in solution and the remainder are those inhibitors. The inhibitors make a huge difference, and they're what all the arguments are about.
Didn't we talk about all these coolants last year? You bet, and we'll probably be talking about them for years to come. Since last year, however, Honda and Toyota have moved strongly into extended-life organic acid technology (OAT) coolants. Yes, DexCools also are OATs, but these Japanese formulas are not DexCool, and the two car companies have indicated they absolutely, positively don't want DexCool-type coolants used in their vehicles.
Nevertheless, you have to pick something to install, and to top up with, and we've learned that the systems are not necessarily forgiving of some mixtures of different coolants. There are circumstances where an unfavorable mixture can cause an increase in corrosion.
Taking these issues a step further, this year we've seen more cases that contribute to coolant confusion. These days, it's all too easy to make a mistake.
You have to appreciate a bit of chemistry about the various formulas. You've got to know in basic terms what's different about the different coolants-both conventional and extended-life types-and what it means when you have to pick one. Yes, that includes a bit about the dye colors.
What's In DexCool?
You should know that the term "orange coolant" has come to mean a DexCool-approved brand but that doesn't mean it's really true. If you make this assumption, you'd be wrong. It's what Fords warning labels could be interpreted to refer to, so that label doesn't serve to clarify things (certainly not when a Ford system contains a very different-non-DexCool, but orange-dyed-coolant). The discontinued Mercury Cougar was an exception; it did contain an orange coolant similar to DexCool.
The "DexCool" designation means the coolant passes General Motors performance testing. Although DexCool is not a specific formula, all three brands that have the label (Texaco Havoline, Prestone Extended Life and Zerex Extended Life) are somewhat similar. In particular, they're OAT coolants, but the similarities go beyond that basic description.
All DexCool-approved coolants to date use two organic acid rust/corrosion inhibitors, one called sebacate, the other called 2-EHA (which stands for 2-ethylhexanoic acid). These organic acids are very stable and last a long time, although they take thousands of miles to become fully effective in protecting coolant passages.
GM recommends a DexCool change every five years or 150,000 miles, whichever comes first. Because most people drive 15,000 to 20,000 miles a year, that translates to a five-year replacement interval. As noted, the thousands of miles required to protect metal is an important trade-off for that longer life. Although like conventional coolants, OATs also contain other inhibitors, for targeted protection.
The inhibitor 2-EHA works well in hard water and is more effective than sebacate at lower pH levels (when the coolant moves from the alkaline end toward the acid side), particularly for cast iron. Well, GM has a number of cast-iron engines. When there's a low coolant level in the coolant passages, the exposed cast iron rusts. Apparently, that rust is washed away later by flowing coolant, and is deposited in the heat exchangers. It eventually produces the rust powder problems that have been so widely observed (see MOTOR's August 2002 issue at www.motor.com). Why does the coolant level in these engines drop? The original radiator cap design was blamed for some of the issue, but there probably are a number of causes, including owner neglect and normal seepage. However, the rust powder issue is not a problem that was observed with the previously used conventional American coolant.
The inhibitor 2-EHA poses another issue: It's a plasticizer (softens plastic), so it has been blamed for coolant passage gasket leakage. Softening (and the resulting distortion) was reported by Ford, which encountered gasket leakage problems when it tested a DexCool-type formula on its V8 engines. Ford also saw similar issues with other gasket materials. That killed the OAT coolant idea for Ford, which had used a DexCool-like coolant in the '99 Cougar V6.
Could that inhibitor be responsible for the intake manifold coolant gasket leakage on GM 60° V6 engines? Or is there some other service issue involved? (After all, GM isn't the only one with coolant gasket leakage problems.) The experts are still working on it.
What Preceded OATs
Until the extended-life OATs came on the scene, there had been primarily two major coolant inhibitors for aluminum protection-silicates and phosphates-and conventional American coolants have used formulas containing both of them. Silicates are related to sand, and there were questions as to their effect on water pump seals. Some old tests seemed to suggest they were harmful, but there has been no credible evidence to support that stance on late-model designs with reputable brands of coolant. In fact, today's carbide seals are about as durable as you can get, and silicates that remain in solution seem to produce no problem anywhere. In real-world evaluations, there's no evidence of any issue, as silicate inhibitors have been used successfully for many decades in all makes of cars. Where a seal-deterioration issue surfaces, it has been attributed to core sand, from failure to clean engine blocks properly.
Silicates protect very quickly, so if there's some mechanical breakdown in the silicate protection, it re-forms very rapidly. For example, a water pump may suffer cavitation erosion/corrosion (a high coolant/ambient temperatures issue, particularly with certain cooling system designs). That means that as the coolant passes through the pump, bubbles are produced, which then collapse with explosive force, pockmarking the internal parts of the pump. That pockmarking is erosion, the marks being exposed, unprotected metal. If the inhibitors work quickly, the damage stops after minor corrosion. If they work slowly (as with organic acid inhibitors), the pockmarked areas corrode for a longer period.
American conventional green coolants use doses of both silicates and phosphates. Phosphates also protect aluminum quickly, but have raised concerns in hard water. OAT coolants contain no silicates and no phosphates.
European coolants also contain no phosphates, but do contain silicates (at a somewhat lower dose than conventional American coolant) plus other inhibitors. These have been used for a long time, and although they're conventional formulas, there are enhanced versions today, as covered in the section on "Other Extended-Life Coolants."
Japanese conventional coolants contain no silicates, but they do contain phosphates for fast-acting protection, plus other inhibitors. Extensive Japanese tests have shown phosphates to be a good corrosion inhibitor for aluminum, and particularly effective in protecting water pumps from corrosion after cavitation erosion/corrosion.
The questions about 2-EHA were raised not only by Ford (and reportedly DaimlerChrysler) but within Japanese coolant development circles, as well. When Honda introduced its long-life coolant, it specifically excluded 2-EHA, and we can tell you there is unhappiness at Honda regarding DexCool in the new Saturn VUE with the Honda-supplied 3.5L V6. The system is being filled with DexCool because that's what s in the plant for everything else. It would not be simple to set up a separate coolant fill system for the Honda engine.
We can't tell you how this dispute is going to play out, but you do have to make a choice when it's time to change. The engine already has been protected with DexCool (unless there's an assembly line change in the works) and it's reasonable to install that when you service that engine. However, to extend gasket life and protect the water pump impeller and chamber, it wouldn't be a terrible idea to flush the system and switch to a coolant with phosphates and/or silicates (conventional American or G-05) at this point.
Ford and Chrysler Group use G-05, a low-silicate, no-phosphate formula long specified by Mercedes, even for its passenger car diesels. Once a similar formula even was made by Texaco for Saturn, with green dye and carrying a 3/36 service interval. Today, the Ford and aftermarket versions have yellow dye-or at least they're supposed to. And the Chrysler Group formula has been dyed orange. Now that we've seen Ford products with orange, it's possible that some of the stuff meant for Chrysler also is being shipped to Ford. Or perhaps it's the DexCool-like coolant used in the old Cougar, although that's doubtful. It's confusing, particularly when you see a "don't use orange" label on the coolant jug and there's orange coolant in the jug.
What is G-05? It's called a HOAT (for hybrid organic acid technology) that today serves for extended intervals, typically 5 years/100,000 miles. Like conventional Euro coolants, it's a low-silicate, no-phosphate formula designed to pass European hard water tests. The reference to OAT in HOAT is for an organic acid inhibitor called benzoate, which actually has been used for many years in almost every American, Japanese and European conventional coolant except what we now call OAT.
Honda and Toyota use a new extended-life OAT coolant-made with sebacate as the only organic acid-no 2-EHA. Sebacate isn't quite as effective in combating corrosion at lower pH levels, but because that's more of a cast-iron issue, it apparently didn't concern the Japanese. Both Honda and Toyota do continue to avoid silicates, but add a dose of phosphates to provide fast-acting aluminum protection, particularly to recoat the water pump after cavitation erosion/corrosion.
What to Use
We used to say that maintaining the coolant level was more important than which type of coolant to use. But there's new evidence that we've been too cavalier in that respect. Sure, for small top-ups or in an emergency situation, it doesn't matter-use what you have. However, there are possible problems with extreme mixtures. An example cited by one coolant chemist: A somewhat diluted mix, perhaps 50% to 60% water, with the remainder (from top-ups) a 50-50 combination of an OAT and a conventional American coolant or a G-05. A remaining inhibitor (borate) could attack aluminum if the silicates are depleted. This becomes more of an issue when a part is being changed, and that new part has no protection against cavitation erosion/corrosion.
Top up with DexCool in GM and VW/Audi vehicles, and '98 Chrysler L/H cars or the '99 Mercury Cougar, if you get one with the original coolant or DexCool. Top up everything else with your second coolant-G-05 or conventional American.
Replacement Parts
Original equipment coolants are validated for factory replacement parts. One of the issues that may arise is the use of an aftermarket replacement radiator or heater core made of copper-brass with lead solder. We have in previous articles pointed out that today's coolant inhibitor packages contain a small amount of copper-brass protection, but may provide little protection if a radiator is made with high-lead solder. Results of industry standard tests of the new Toyota extended-life coolant now show a substantial weight loss (corrosion), both in a 50-50 mix aud in a 33% coolant mixture (solder corrosion is much greater in this more diluted solution).
If you have to change a radiator or heater core, use aluminum. Or, if it's an older car and the owner wants the lowest-cost radiator, you might procure a soldered-together copper-brass unit. Conventional American coolant should provide better protection against solder corrosion, which can result in radiator tube restrictions and leaks. But no coolant provides perfect protection.
If you're replacing aluminum parts on an engine, such as a water pump or even a new cylinder head, remember that part's coolant passages have not been protected. In those cases you should perform a complete coolant exchange.
Complete Coolant Service Choices
Chances are you'll standardize on two coolants to cover most situations. One will be a DexCool formula; the other could be a G-05 extended-life or a conventional American (green or gold). A better approach would be to have all three coolants. When it comes to what to use and when, here are recommended or suggested strategies:
GM and VW/Audi vehicles. For these applications, use DexCool because that's in accordance with factory coolant formula recommendations. Sure, the vehicle probably will be out of warranty by the time you get it and have to make a decision. But the OE recommendation is the safe way to go, and because you can easily obtain a DexCool, it's a no-brainer.
Ford and Chrysler vehicles. Here again, it's a no-brainer. Both companies have identified problems with DexCool, so use something else. G-05 is available in the aftermarket, so that's your choice for extended life on vehicles from those makers. However, if your second coolant is conventional American, that's fine. The recommended service interval is shorter, but if the coolant level is maintained and the motorist is not a high-mileage driver, it can serve beyond two years. In fact, Ford long recommended four-year intervals with conventional American coolant.
Japanese vehicles. This is a problem area, because Japanese-spec coolants have never been sold in the U.S. aftermarket and history says conventional American coolants work well in these vehicles. Toyota research indicates the new extended-life coolant contains phosphates to protect the water pump, and DexCool contains no phosphate. Honda has said it will not use a coolant with 2-EHA. So both carmakers exclude DexCool. Best solution with aftermarket coolants: Do a complete coolant exchange, and replace the Japanese OE coolant-conventional or extended-life-with conventional American or G-05.
Coolant Exchange
Never before has the capability to do a complete coolant exchange been more important. Even if you're changing a DexCool system and putting in new DexCool, you want to get the system full, really full. A low coolant level is bad news, particularly with cast-iron engines. Even if the engine is aluminum, a low coolant level could mean engine-damaging temperatures and surely cause poor heater performance in winter. With today's smaller coolant capacities, the system doesn't have to be low by much for problems to surface.
If you're making a change in coolant type, such as any Japanese coolant to American green or G-05, you should get at least 90% of the old stuff out. The only way to do this and ensure a full system when you're done is with coolant exchange equipment.
A complete coolant exchange can be done manually, if you have a lot of time and infinite patience, plus a willingness to lose money on the job. In addition to the coolant exchangers already on the market, we've been seeing new ones designed to handle two or more coolants. They're a recognition of the many different coolants currently in use.
Whatever the coolant, remember the other half of the mixture is water. In hard water areas, always use demineralized water. Some coolant formulas are more tolerant of hard water than others, but that doesn't mean it's good for them.
Visit www.motor.com to download a free copy of this article.
Copyright Hearst Business Publishing Aug 2004
Provided by ProQuest Information and Learning Company. All rights Reserved
blackink00
I missed a shift & stole Curt's money.
Mar 30, 2005
545
Tempe, AZ
Dec 13, 2005
#13
  • Dec 13, 2005
  • #13
i thought by law jiffy lube cannot add to brake fluid because its an indication that the pads are low and if you add more the pads will soon wear all the way down. it could cause an accident and therefore it leaves a big liability with them
Outlaw97GT
234
Redneckville, Tx
Dec 13, 2005
#14
  • Dec 13, 2005
  • #14
Yeah they are known for doing stupid stuff to customers cars. But what do you expect from kids 18-22 making min. wage.
I wouldnt let them check the air in my tires!
W
warrior86
18
#15
  • Dec 18, 2005
  • #15
thanks for all the replies. I flushed out my system pretty thoroughly with water like 5 times and then with prestone "flush" until only water was being drained. I hope i didnt hurt anything by it being in for those summer months.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Dec 18, 2005
#16
  • Dec 18, 2005
  • #16
Don't worry, you didn't.
CRZYHRSGT
240
5.7 miles north of THE Ohio State University
Dec 20, 2005
#17
  • Dec 20, 2005
  • #17
Indeed! I couldn't tell you how many belly pans, oil pans and engines I've sold over the years because of the yahoos at Jiffy Lube and Wal-Mart. I'm pretty sure that their only job qualification is that you have a pulse!
carbed87
215
#18
  • Jan 2, 2006
  • #18
thats true for grease monkey as well (thats where ive been working for the past 2 years )
some of the dumbasses that this company hires... oh man, i should just write a book on the chit.
i think the most memorable moment was when we hired this fat bi-lingual mexican lady. she seemed nice enough, and did her job quite well, but the second day she worked, @ about 10am, 4cop car, 1swat truck, and a partridge in a pear tree shrug: ) all pull up with guns drawn, pull her out of the car she was vacuming BY HER HAIR! and arrest her for:
-homocide
-sexual assualt
-and 2 counts of arson
i **** you not, ALL of it is 100% true, not exadurated at all. after it was all said and done, we were in tears we were laughing so hard. the customer in the lobby freaked the **** out! lol o man, i've had some good times there.
but yeah, you can't mix green and dex cause the chemical structures are a little different from what ive been told
if i remember correctly, green coolant is ethylene glycol while dex is propelene glycol. but you can just flush the whole thing dex, but like everyone else says, its kinda pointless.
CRZYHRSGT
240
Jan 2, 2006
#19
  • Jan 2, 2006
  • #19
This is much like VW/Audi's blue vs. pink coolant. Blue is great, pink is great, but shame on you if you ever mix the 2 together. According to the manufacturer the 2 mixed will erode rubber seals/o-rings. Great design, if you ask me...
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Engine Head gasket or what?
  • Foxbody1988
  • Jan 17, 2020
4K
Fox 5.0 Mustang Tech Jan 19, 2020
7991LXnSHO
Dex Cool Question
  • IIGood
  • Mar 16, 2017
  • Other Auto Tech
3K
Other Auto Tech May 25, 2017
giddyup306
P
Coolant
  • Patriotu
  • Nov 8, 2016
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Nov 25, 2016
Luckyloke
For Sale 1994 GT 5L Trickflow h/c/i Tremec TR3550 Saleen copy - $7000 (Ann Arbor, MI)
  • no_fox_given
  • Mar 21, 2019
9K
SN95 Mustangs For Sale (1994-04) Mar 21, 2019
no_fox_given
