V6's use 8.8s?
Well doing a gear swap on my 95 and I find a bad axle... it'll be 80-120$ for a new one and i'd just as soon find one at a JY.... I know where there is a 98 V6, but would it have the same axle? Would it matter if it has ABS or not (mine doesn't). I know ABS has the magnetic wheel but is the length or any other critical dimensions different?
some stuff that you can use from the V6 Rear end:
Axles
C-clips
Control Arms
ABS if equipped (rare)
Brake Setup (minus metal line that runs acrossed the rear)
Springs
Shocks
Sway bar
All that stuff is 100% the same.
Can't use:
Gears or Differential
I have a collection of Axles at home.. I'll goto a junk yard and ask for some out of a GT and get quoted 100 bucks for a set or 25 for the V6's. So i always by the V6 stuff :) I hord all kinds of getting hard to find 5.0L parts like wiring, input shafts, bellhousings, Brackets. Since these cars are a 2 year make. Other car with same parts engine wise (i know off topic :) ) is 91-93 T-birds with 5.0L engines.
