Vaccum issues
  • Thread starter Thread starter ddt4436
  • Start date Start date Sep 8, 2009
D
ddt4436
70
  • Sep 8, 2009
I have a 90 mustang gt all stock except eddy intake. It idles really bad to the point of it cutting off along with not staying crunk at all. I can hear air being sucked from behind my brake booster under the inside of the dash and the brakes ar horrible. Can there be a possible vacuum leak under there causing it to horrible idling and poor driveability? Please Help!
I
irish
168
Florida
Sep 8, 2009
  • Sep 8, 2009
I'm not sure what "crunk" is but if you can hear a vacumn leak, then you need to find out what/where it is leaking from and yes it will make your car run badly.
Matt
D
ddt4436
70
  • Sep 8, 2009
My bad, crunk=running. My question is does the brake booster need changed or is there a vacuum line up in there under the dash? I never had a mustang to hiss from under the dash interior by the brake booster. Any more suggestions?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 8, 2009
  • Sep 8, 2009
If you hear the vacuum inside the car, the booster is suspect. However, I recommend replacing the rubber grommet that the brake booster check valve mounts in. The brake booster check valve is the metal fitting that the large vacuum hose connects to. The rubber grommets crack and harden with age and heat, so they often leak.
The other source of interior cabin vacuum leaks is the HVAC controls that control airflow for the heating and cooling. If your HVAC works OK, then this is not a suspect.
D
ddt4436
70
  • Sep 9, 2009
Thanks alot J! That made a lot of sense. I'll check that today.
D
ddt4436
70
  • Sep 11, 2009
Ok here's what happened. I took the large hose off the brake booster and plugged it and the car idled perfect. Hooked it back up and horrible idle again. I'm trying to figure if the problem can be fixed without removing the booster as that is alot of work.lol. I did check the grommet and it looked cracked but I don't know if that crack is pulling in all that free air coming into the booster.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 11, 2009
  • Sep 11, 2009
Replace the rubber grommet. If you get a remaufactured booster, the gromment may not come with the new part. If the grommet fixes the problem, you saved some $$$, some sweat and skinned knucles.
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Saturday at 9:49 AM
CAMTWO1070
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
T
Resolved No run or idle
  • Thebluefox1
  • Oct 10, 2025
Fox 5.0 Mustang Tech Nov 25, 2025
DadLife0724
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
D
Foxbody Misfire 5.0 Swap
  • DPORTER0729
  • May 2, 2025
Fox 5.0 Mustang Tech Jul 13, 2025
90sickfox
