vaccum line question
  • Thread starter Thread starter superspec
  • Start date Start date Aug 4, 2009
superspec
78
  • Aug 4, 2009
theres is a vaccum line coming from the bottom of the intake going to the right front frame to some box. what is that line for? after pulling the upper intake and not knowing that vaccum line was there it tore. i replaced it with some randome hose that fit but the hose isnt rdgid enough and is collapsing. just trying to figure out what the hose is to determine if it will hurt to drive the car the 10 miles to get another hose.
ShortThrow50
923
Pa
Aug 4, 2009
  • Aug 4, 2009
that hose goes to the fuel vapor canister (charcoal canister). there is a line that gores from that canister back to your fuel tank for ventilation. Yeah, just get some vacuum hose from napa auto parts. they have every size hose and you can cut whatever length you need. I think i actually got fuel hose from napa. If thats your only means of commuting, i wouldnt worry about it and drive the 10 miles so you can get the part.
superspec
78
  • Aug 4, 2009
ok, thanks. i figured it had something to do with emissions crap.
V
v8only
2,378
22
49
Aug 6, 2009
  • Aug 6, 2009
it's more than that....leave that stuff off, and enjoy problems such as bad gasoline vapor smell
J
Jeffs88
86
Northeast Ohio
Aug 6, 2009
  • Aug 6, 2009
Do the canisters ever wear out? Mine is hooked up but i'm still getting the gas smell....
88 5.0
Jeff
UPRMike
26
Lake Worth, Florida
Aug 6, 2009
  • Aug 6, 2009
88 5.0
Jeff
Yep, they can get a little funky after a couple decades. It's not too expensive to replace:
79-95 Charcoal Canister, 5.0L at LRS - Same Day Shipping!
V
v8only
2,378
22
49
Aug 6, 2009
  • Aug 6, 2009
trace the lines too
there is a soft line..a rubber line that connects the two hard lines under the car pass side towards the rear wheel. that line can rot away, and the fumes will exit there too
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 6, 2009
  • Aug 6, 2009
Charcoal canister plumbing - one 3/8" tube from the bottom of the upper manifold to the rubber hose. Rubber hose connects to one side of the canister solenoid valve. Other side of the solenoid valve connects to one side of the canister. The other side of the canister connects to a rubber hose that connects to a line that goes all the way back to the gas tank. There is an electrical connector coming from the passenger side injector harness near #1 injector that plugs into the canister solenoid valve. It's purpose is to vent the gas tank. The solenoid valve opens at cruse to provide some extra fuel. The canister is normally mounted on the passenger side frame rail near the smog pump pulley.
The purge valve solenoid connector is a dangling wire that is near the ECT sensor and oil filler on the passenger side rocker cover. The actual solenoid valve is down next to the carbon canister. There is about 12"-16" of wire that runs parallel to the canister vent hose that comes off the bottom side of the upper intake manifold. That hose connects one port of the solenoid valve; the other port connects to the carbon canister.
Purge valve solenoid:
The carbon canister is normally mounted on the passenger side frame rail near the smog pump pulley.
Carbon Canister:
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
Vacuum line question?
  • Mustang Momma
  • Feb 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 3, 2026
M
  • mnky99
  • Sep 5, 2025
mnky99
M
C
Engine Code 13 and high idle
  • CmdrDerp
  • Dec 14, 2024
Fox 5.0 Mustang Tech Dec 21, 2024
manicmechanic007
