Vaccum line through Driverside fender
mavmavv
185
Where does the vaccum line that goes through the driverside fender end up? I have a few more things to check and fix before I smog this bitch.
Still have that stupid wiring gremlin and I want to make absolutely sure I dont have even the slightest vaccum leak, I have a tiny miss at idle when cold.
I think that there is a vacuum reservoir up in there
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
Ignition switch wiring
Fuel pump, alternator, ignition & A/C wiring
Computer, actuator & sensor wiring
Fuse panel layout
Vacuum routing
