  • 1994 - 1995 Specific Tech
Vaccum Problems...
  • Thread starter Thread starter Piston
  • Start date Start date Jun 8, 2004
Piston
215
Chicago Suburbs
Jun 8, 2004
  • Jun 8, 2004
Does anyone have a vaccum diagram for a 94/95 stanger. Just dropped in a new motor and the project took longer then expected. Now I'm not so sure where everything plugs in. Should have taken some notes...
94TURBO5 O
2,509
VA
Jun 8, 2004
  • Jun 8, 2004
There are not to many vacuum lines. Do you need to connect all of them or are you just lost on a couple?
Piston
215
Chicago Suburbs
Jun 8, 2004
  • Jun 8, 2004
I need to know where to plug in that canister line that comes off the firewall on the passenger side.
94TURBO5 O
2,509
VA
Jun 8, 2004
  • Jun 8, 2004
What color is it?
Piston
215
Chicago Suburbs
Jun 8, 2004
  • Jun 8, 2004
Its a black rubber hose, just after a small canister that is wrapped in black foam.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Jun 8, 2004
  • Jun 8, 2004
where is the canister along the fire wall, driver side, pass side. pics would really help.
EDIT- never mind you did mention it
94TURBO5 O
2,509
VA
Jun 8, 2004
  • Jun 8, 2004
It goes to the bottom of the intake on the other nipple. One to pcv and the other to your mystery hose. It is the one that has a plug in the bottom right?
RIO5.0
6,892
N.H.
Jun 8, 2004
  • Jun 8, 2004
This may help...its a stock upper...the line your after is the one that feeds under the intake in the middle...it feeds what your talking about...The one on the neck (large) feeds the vac Tee on the drivers side fenderwell...the line above it (small loop) feeds the FRP...
Piston
215
Chicago Suburbs
Jun 9, 2004
  • Jun 9, 2004
Thanks guys I think I got it!
T
tb94gt
#10
  • Jun 24, 2004
  • #10
Helped me too!!
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
393W Stroker with Boost - Need Spark Plug Recommendations
  • 387lx
  • Apr 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2026
HotFox
  • Mindseye007
  • Aug 16, 2026
Mindseye007
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
