Vaccume Pump Tech
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Just want a get a little info on these. I have been hearing a lot about Vaccume Pumps, but the search didn't come up with much. Who is running one and what do you think of it? I have heard it really helps ring seal and is a very "worthwhile" mod on a high output motor.
Well, I'll be damned. No wonder I can't find any info on it.
Vacuum :doh:
I never won a spelling bee, if it wern't for my last name starting with a W, I wouldn't even make it to the end of round 1. :D
what do you want to know about them?
They are mainly used when low tension rings (.043 top ring for example) are used so that it helps ring seal, it also reduce's crankcase pressure , I wouldnt really suggest these for a street engine but it may be fine with a small amount of vacuum. Def dont use on a new engine untill the rings are seated...
stroked86 said:
look above what else do you need to know?
How much vac is usually needed to get noticeable benefits?
Is the vac pump driven with the acc. belt?
Does anyone use engine/intake vac to provide the vac?
Once air has been pulled from the crankcase where is it usually routed?
All I can think of right now. Got any links? I would love to see a diagram or some pics.
Oh yeah, thanks alot for the info. It is appreciated.
electric pumps work ok.... no you cant use the engines vacuum, for one the area its pulling from is to large and it would create a vacuum leak second there is no where to put the oil if a little gets puleed out which usually happens... usually the good pumps are belt driven and on our outlaw car we like around 12-14inches to be pulled... from the vacuum it gos to a overflow canister..
http://store.summitracing.com/defau...earchinresults=false&N=0&target=egnsearch.asp
So could you use engine vac if you had a seperator? Maybe one of the $12 ones from Home Depot, or one of these... MOR-85465 Moroso's oil seperator/breather/accumulator.
As far as the vac leak goes, I am thinking about blocking off the inlet to the crankcase since I already have a vac leak through the pcv valve from the TB/VC hose. It sounds like doing this would give me crankcase vac?
Have you guys had any issues with collapsing gaskets/seals?
Those pumps sure are pricey!!!
if you tried to use engine vacuum it would cause a vacuum leak, to much area to pull from unless the engine was 100% air tight then it might work but then the vacuum would probably vary to much
First, I really enjoyed all the info, and greatly appreciate your effort.
I do still have a question though. You have mentioned that using engine vac would not work because there is "too much area to pull from"
Are you saying that the crankcase is too large of a volume for the engine vac to be effective?
I am very confident that my crankcase is fully sealed, and have yet to find any external vac leak in the intake (and I have looked).
All current motors come from the factory using intake vac to vent the crankcase, that is how the pcv works. Well actually it is the pressure difference between the intake and crankcase. Basically, the stock setup, with pcv and hose between TB & VC, has a vac leak.
In a perfect world, one would not need to add an external air pump to the engine to achieve a vac on the crankcase. The motor itself is a great air pump. I guess I just don't understand how the volumes of the intake and crankcase come into play. Can you (or anyone else) elaborate on this for me?
thanks again
jason
