vaccuum test??
jimsstang91
101
i have the trick flow h/c/i stage 1. i did a vacuum test and i was getting 30 inches of vacuum at idel. the tech from trick flow said i should have 14?? with the stage 1 cam. check the manifold bolts. go 10-15-20 they were lose at 10 can this cause a vacuum leak.???
Awesome cam - about 50% more vacuum than the stock cam has. That will work great on a SD set-up.
Are you real sure that gauge is accurate? That is the first question I had to ask.
Good luck.
