C CaspersFoxes New Member Apr 11, 2011 29 0 1 South Carolina May 29, 2011 #1 May 29, 2011 #1 my car's running a little rough since the rebuild. it spits and sputters at around 4k and it idles rough once in a while, so rough some times that it kills itself
408WBlackCoupe Member Jan 3, 2011 29 1 6 May 29, 2011 #2 May 29, 2011 #2 Check all Vacuum lines and spray around the intake to check for leaks. Doesn't sound like timing to me.
C CaspersFoxes New Member Apr 11, 2011 29 0 1 South Carolina May 29, 2011 #3 May 29, 2011 #3 will do, appreciate it!
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 May 29, 2011 #4 May 29, 2011 #4 You don't happen to have platinum plugs do you? On some cars, they can cause a low/rough idle and cutout at 3500-4K RPM.
T TokyoJoe New Member Mar 25, 2007 179 5 0 May 29, 2011 #5 May 29, 2011 #5 Carb or EFI? 4k sputter sounds ignition related. Plugs, wires, cap all in good condition?
C CaspersFoxes New Member Apr 11, 2011 29 0 1 South Carolina May 30, 2011 #6 May 30, 2011 #6 actually i do have platinums, and its efi, i got a new cap and rotor and accel wires
C CaspersFoxes New Member Apr 11, 2011 29 0 1 South Carolina May 30, 2011 #7 May 30, 2011 #7 HISSIN50 said: You don't happen to have platinum plugs do you? On some cars, they can cause a low/rough idle and cutout at 3500-4K RPM. Click to expand... is there a plug you recommend?
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,366 18,112 224 Massachusetts May 30, 2011 #8 May 30, 2011 #8 Stock oem copper motor craft plugs
