I made a previous post about a high idle problem after installing a new intake, and some of the feedback I got suggested that it could be a vacuum leak.
After acceleration it idles between 1700 and 2000 rpm. I can unplug the IAC and it drops back to normal. I plug it back in and it jumps up to 2000. I've tried a restriction plate on the IAC, but that just created different problems so I took it off. I replaced the IAC assembly and it is clean and not stuck, installed new throttle body, installed new computer, and I have a bypass plate on the IAC but nothing has helped.
Is this characteristic of a vacuum leak? I figured if it were a vacuum leak it would idle high no matter what, but I can unplug the IAC and it idles normal. I can't figure out why changing the intake would make the computer keep the IAC valve open.
