vacuum line diagram
Does anybody have a vacuum line diagram for the gt40 tubular intake, on the 5.0 mustang?
Vacuum line connections:
One large vacuum line from the upper front goes to the carbon canister
One large vacuum line from the rear goes to the vacuum tree.
One small line in the front feeds the Smog pump solenoid control valves on the rear of the passenger side wheel well..
One small line in the rear goes to the fuel pressure regulator.
One small line in the rear goes to the EGR suction regulator.
One large line in the rear goes to the PVC valve.
Vacuum diagram 89-93 Mustangs
Canister purge valve and fuel pressure regulator need their own independent manifold port due to possibly sucking fuel in. Also, if speed density, you want a direct port into the intake manifold as well. No taps or connecting to vacuum tree
Reactions: limp
Reactions: 85GTStangGuy
