  • 1994 - 1995 Specific Tech
Vacuum line help
  • Thread starter Thread starter Artyom
  • Start date Start date Aug 27, 2024
  • Tags Tags
    95 5.0 hesitation vacuum line
  • 3
First Prev 3 of 3
A
Artyom
32
USA
Sep 26, 2024
#41
  • Sep 26, 2024
  • #41
Update: After taking my time and not rushing anything I finally got everything back together. Cleaned the injectors, fixed some exposed wires on the passenger side fuel rail, replaced pigtail to TPS, replaced TPS, cleaned the throttle body, fixed the treads on the lower intake that bolts the upper to it, and replaced the schrader valve on fuel rail.
Went to start the car with very low expectations. Unsurprisingly the car won’t start. It cranks but after a few cranks it will drop in rpms/cranks slow down for a crank or two then goes back to normal cranking. It does this on and off when trying to crank the car. And will sound like it back fires a little on a few cranks. I did pull the distributor up a little when I was fixing stuff so I could free a plug that would otherwise run into the distributor if you tried unplugging it. However the distributor was not fully removed and I made sure to mark its original location. Could my timing somehow gotten messed up?
Quick edit: I pushed the little pin in the schrader valve down to see if there was pressure, it didn’t shoot out gas like it did before one time. Instead gas just flowed out. When I get the chance I will rent a gauge to check my fuel pressure.
  • 3
First Prev 3 of 3
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
Intake vacuum lines
  • cnorman31
  • Mar 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 15, 2025
Scrapla347
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
