vacuum line routing
Ok just took off smog pump and A/C, and was wondering the exact way i should reroute these vacuum lines. i have 2 big lines running from the upper intakes 2 sided larger tree, one to the pcv valve the other to the tree mounted on the drivers side fire wall. Ive got 1 red line from FPR to the smaller tree, and 1 long black line from what looks like the EGR tree towards the passenger side. The rest of the lines are all plugged on the intake. The charcoal canister was also removed, will the car run right without the canister, it did have a solenoid going to it that i was worried about. Also there is a black line running along the passenger side that connected to the canister that smells like gas, if its ok to not have the charcoal canister what should i do with this line is it ok to plug it or do i need to reroute it. If you need more info i may be able to get pics, thanks in advance...
