vacuum routing for holley systemax 2 intake?
Boostedpimp
May 8, 2003
1,451
493
154
NJ
Installed a systemax 2 combo on my daily driver and it previously had the stock intake so Im not really sure how to route the vac lines.. hoping someone with this intake can help me out
thanks
ok so no one out there has a holley systemax intake on there car...
would anybody be able to tell me then if the egr and fpr can share the same vac port on the intake manifold or does the fpr need it's own.. Im thinking it needs it own and the same goes for the map sensor
Im pretty sure that the MAP sensor and the FPR both need there own dedicated lines... so with that I have no idea where to tie the MAP sensor in because the vac ports on the upper are all taken up from what i've come up with unless someone else notices something I can change or have wrong.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
Yeah saw that vac diagram but the stock intake has many more vac ports on it then the holley does... so I have to find out or figure out how to get a vac line to the egr solenoid on the shock tower or just delete it I guess.
