Vacuum Routing
aNotchAbove
75
Can anyone tell me which vacuum line goes where? Its a Trick Flow intake.
Vacuum lines aren't particular where they go, as long as they ft tight and don't leak. The only thing that you should not share vacuum with is the fuel pressure regulator. It should have its own dedicated vacuum line.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
Ignition switch wiring
Fuel pump, alternator, ignition & A/C wiring
Computer, actuator & sensor wiring
Fuse panel layout
Vacuum routing
