Vacuum Tree
  • Thread starter Thread starter Black Sun 5.0
  • Start date Start date Mar 17, 2009
Black Sun 5.0
1,337
L.I., N.Y.
Mar 17, 2009
  • Mar 17, 2009
So I have my car put back together, and sent it to the machanic to button-up a few things. I noticed over the weekend that the vacuum tree by the firewall is totally busted up. How involved is it to redo the vacuum lines? Also, what impact does this have on the car (performance, problems, etc.). There's a reason why I'm asking 'silly' questions, but I need confirmation of something. Thanks.
4G-KDMP
935
CA
Mar 17, 2009
  • Mar 17, 2009
If you're going to re do them ( completely replace the old lines) the only vacuum line that would cause you any grief would be the line that goes to the cruise control because it goes to the servo and that is tucked you by the drives door under the splash shield, the rest of the lines are fairly easy to reach.
With your Vacuum Tree busted up you have a vacuum leak and the problem with a vacuum leak it that when you first start the car it doesn't want to run and most times it will backfire in the intake. Once it's warmed up it seems to run fine but it always sounds l;like you have a big lopey cam in the car.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 17, 2009
  • Mar 17, 2009
Other than the performance problems caused by a vacuum leak, the vacuum tree isn't anything special. It is nothing more that a piece of plastic with a bunch of places to connect stuff. All you have to do is be careful not to break anything that you don't have a replacement for close at hand.
The diagram below is for an 89 5.0 Mustang . The 86-88 5.0 Mustangs will be similar with the addition of a vacuum line from the intake manifold to the MAP sensor mounted on the firewall next to the vacuum tree.
Black Sun 5.0
1,337
L.I., N.Y.
Mar 17, 2009
  • Mar 17, 2009
Doesn't poor vacuum also affect other things such as breaking, idling, etc.? I think cruise control is the least of my problems right now, I can't go cruising anywhere at this point. Then again, I think it's the only thing that works on the car.
HISSIN50
34
129
Mar 17, 2009
  • Mar 17, 2009
You can get a nice metal vac tree in the aftermarket (they are pricey) or make one from parts at the local hardware store.
4G-KDMP
935
CA
Mar 17, 2009
  • Mar 17, 2009
When I said run earlier I should have included and poor idling also.
With the Vacuum T busted and not being a sealed unit any components that needs vacuum will be effected so yes the brakes, HVAC, etc, will be effected by the loss of proper vacuum.
Black Sun 5.0
1,337
L.I., N.Y.
Mar 17, 2009
  • Mar 17, 2009
Maybe I asked the wrong question: the T is in good shape, it's all the lines running from it that are busted.
4G-KDMP
935
CA
Mar 17, 2009
  • Mar 17, 2009
Sorry my misunderstanding....... I read it as
[I noticed over the weekend that the vacuum tree by the firewall is totally busted up.
Yes any cracked or disconnected vacuum line can and will cause you problems. The hard part is usually finding them.
Black Sun 5.0
1,337
L.I., N.Y.
Mar 17, 2009
  • Mar 17, 2009
Oh, trust me, there's no problem finding the bad lines here.
HISSIN50
34
129
Mar 17, 2009
#10
  • Mar 17, 2009
  • #10
You can get bulk hard lines at the parts store. I prefer to use rubber vac line (grab several feet of every size) and replace them one at a time.
4G-KDMP
935
CA
Mar 17, 2009
#11
  • Mar 17, 2009
  • #11
If you have the leaks found you've got 80% of the battle won, now it's just a process of replacing those lines.
As suggested by HISSIN50 you can get rubber as a replacement which seem to be easier to find that the hard plastic lines , that option is up to you though.
Black Sun 5.0
1,337
L.I., N.Y.
Mar 19, 2009
#12
  • Mar 19, 2009
  • #12
Hey, any way of getting a printable version of that diagram?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 19, 2009
#13
  • Mar 19, 2009
  • #13
Click on the diagram to make it the maximum size. Then right click anywhere in the middle of it. Select copy from the dialog box.
Go Start, Programs, Accessories and open Paint. From Paint's Edit menu select Paste. The diagram will paste onto the blank page. Do a Save As to keep the copy or select Print from Paint's File menu.
4G-KDMP
935
CA
Mar 20, 2009
#14
  • Mar 20, 2009
  • #14
^^^ exactly!
Black Sun 5.0
1,337
L.I., N.Y.
Apr 6, 2009
#15
  • Apr 6, 2009
  • #15
Another question about having NO vacuum: how does this affect fuel delivery, if at all? I get smoke that wreaks of fuel coming from my exhaust and I'm just trying to determine if it's related. It doesn't appear to be coolant or oil related and seems to increase after the car has been running a while.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 6, 2009
#16
  • Apr 6, 2009
  • #16
No vaccum to the fuel pressure regulator will definitely upset things and make the air/fuel mixture too rich.
Black Sun 5.0
1,337
L.I., N.Y.
Apr 6, 2009
#17
  • Apr 6, 2009
  • #17
That's what I was thinking, I just needed some confirmation. Thanks again.
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Vacuum line question?
  • Mustang Momma
  • Feb 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 3, 2026
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
