• Community Forums
  • Regional Forums and Event Information
Valve clearence?
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date May 3, 2005
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
May 3, 2005
  • May 3, 2005
so whats the easiest and best way to check valve clearence so they dont smack the piston on a 95 5.0? peace
john
stock50LX
Curmudgeon
1,858
University Place, WA
May 3, 2005
  • May 3, 2005
john
Put clay on top of the piston near the eyelits cut for valve clearance. Reassemble one cylinder with intake and exhaust valves (use very weak springs if you have them). Tighten the heads using a couple bolts. Install pushrods and adjust valve lash. Using solid lifters if possible, or well oiled hydraulics if you must, rotate the engine crank through two complete rotations. Then remove the head, peel off the clay and cut the clay in half to check valve clearance. I recommend a little light oil to keep the clay from sticking.
WaterPog
2,201
Portland, OR
May 3, 2005
  • May 3, 2005
Use Silly Putty instead of clay, it holds it's shape just as well but doesn't stick to anything.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
May 5, 2005
  • May 5, 2005
do you guy's think this will still be an issue with stock heads from an 87-93 5.0? the heads have been worked over. peace
john
Does anyone else have a combo close to this
  • 90Stanger302
  • Dec 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 25, 2025
Qtrhrse23
Q
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
03 Mustang, found dinged pistons, pics.
  • 2003 mustang gt modded
  • Aug 8, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 19, 2025
Valve hitting piston?
  • krazedstang
  • Jun 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 12, 2025
Vortech v3 Si Blow-Off Valve
  • seanmahoney
  • Jun 9, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jun 9, 2025
seanmahoney
  • Community Forums
